Van Solo
Van Solo
Van
Calgary / Canada
Hello.
Question for anyone who has already installed with the parking mode wiring from the overhead console.
When you went through the liner, towards the mirror (to connect to the dash cam) what's the best route so that the wiring is best hidden and out of site.
It is probably obvious when I get into it tomorrow but I thought I would ask the ones that have already installed it.
Appreciate any input. Thank you in advance.
Follow your instinct, you will see the path. lol
ecornista
Nevada
camry
Hey everyone who set up this on your 4Runner! I’d love to hear your thoughts on the installation—what went well, and if you ran into any snags along the way.
Ahmad310
Ahmad
Cincinnati, OH
2025 4Runner Platinum
Trying to do my install now, got the old housing off but cannot get the overhead panel off. Pulling from the front with a lot of force and it’s not budging.
ToYoDaMan
Allan
Bay Area
I will be installing later today. Thanks for the heads up!
Ahmad310
Ahmad
Cincinnati, OH
I finally got it, took a lot of force. Be careful not to pull down the bezel that goes around the housing or you will break tabs.
ToYoDaMan
Allan
Bay Area
Thanks for the tips. That's exactly what happened . The bezel partially came off and then the console came down with a bit more force.
my problem now is that when connecting to my iPhone, it went into a weird loop with my car Toyota app.
finally I was able to connect the camera. When I open the app, I see the name of my camera but the app asks me to connect to camera
again since the car is on, it goes into a loop with the Toyota connection and app.
are there any settings I'm suppose to apply so it just connects and does not have any conflicts with the Toyota app and other connections in the Runnwr while it's on?
I've had other dash cams and doesn't have this conflict. Weird.
Update:
Only way I get to connect to the FITCAMX is to turn off my cellular data and my Bluetooth.
It works this way per their instructions.
Other than that, if I keep the current settings on my iphone, it's always unsuccessful.
ToYoDaMan
Allan
Bay Area
I have an old iPhone 11 Pro that I will be using to connect to the FitcamX.
My primary phone settings will remain as is and connects to the Runner app and CarPlay, etc. and not complicate things
Clipse
Seattle, WA
2025 4Runner TRD ORP
thanks for the writeup and pictures. It was really helpful with the install this morning. Only issue was pulling down on the rearview housing and snapping a clip.
Is anyone else having similar issues like ToYo with the connection looping? After fighting with the car 4-5x it finally let's me connect and view the camera briefly. How are y'all mitigating it? I'm not carrying a second phone for this.
ToYoDaMan
Allan
Bay Area
@Clipse , only way I know how with my primary phone is to temporarily disconnect Bluetooth. If that doesn't work. disconnect both Bluetooth and Cellular data.
this is the only way to connect the dashcam to the app and view your files and view live.
after doing so, you can put your settings back on, Bluetooth and/or Cellular data so that your phone can connect back to Apple CarPlay.
Another way you can deal with it is to turn of your Bluetooth , so that you can connect your dash cam app and then hard wire your phone to the Runner for apple CarPlay.
Doofy
Hamilton, ON Canada
2025 4R
think about it - it isn't really possible for a phone to connect to two different bluetooth items at the same time, so you kinda need to disconnect one to access the other.
i'm not a techy, but that makes sense to me. annoying, but makes sense
Clipse
Seattle, WA
Thanks for the tip @ToYoDaMan! That's makes a lot of sense
@Doofy the issue isn't that your phone can't connect to multiple Bluetooth devices--it certainly can. The issue is more of with Bluetooth turned on, Toyota forces the wifi to disconnect, and the app requires wifi connection. That's where I was caught in the loop--definitely user error.
Peter
Peter
Thanks for the write-up and info! I installed this FitcamX on the weekend, including the rear camera. Other than breaking tabs getting the overhead console down, everything went smoothly and I am very happy with the clean installed look of both cameras.
2025 2026 4runner 6th gen FITCAMX dash cam install - step by step how-to DIY (on 2025+ 4runner 6th gen) IMG_5050
2025 2026 4runner 6th gen FITCAMX dash cam install - step by step how-to DIY (on 2025+ 4runner 6th gen) IMG_5052
2025 2026 4runner 6th gen FITCAMX dash cam install - step by step how-to DIY (on 2025+ 4runner 6th gen) IMG_5051
Ahmad310
Ahmad
Cincinnati, OH
Did you break tabs on the bezel or the actual housing? I pulled the bezel off trying to get the housing out and broke several of the clips and cracked the bezel. Looked to see if you could buy just the bezel, and could not find it, just the whole overhead panel which was close to $400... But I did find a take off on eBay from a Tacoma for $90 for the whole assembly, so i picked that up, removed that bezel and installed in mine, all good now!
