Eliminating Toyota's Double Honk
Desert_6Gen
Eric
Bronco
I've searched the setting to no avail. Is there a way to turn off the annoying double honk/beep when you close the door with the fob in your pocket and vehicle running? I don't want everyone around me to look and realize I'm leaving my vehicle while it's still running.
Scrappopatamus
Barry
Midway KY
Pick up a Carista on Amazon and change many of the setting in your 4Runner, or you can take it to your dealer and pay the man.
rogueclimber
Rob
Marina del Rey/Phoenix
2026 4Runner TRD Pro
Indeed, but not sure if you can turn off that double beep while the engine is running (I don't see it on the carista site, nor do I remember it when I was turning off all the other annoying dings)
only way around it is to leave the fob in the vehicle
Papa Smurf
Alberta
4 Runner TRD PRO
Most annoying feature ever! I know with Ford if you have there Forscan software you can turn it off and Toyota may be able to do the same. Here is what I found on the internet so it has to be true lol.
Methods to Disable/Manage the Double Honk:
  • Dealer Service: Ask a Toyota dealership to disable the "smart key removed from vehicle" audible alert, which is a common fix.
  • OBDII Scanner: Users have reported success using tools like OBD Fusion or other advanced scanners to modify BCM (Body Control Module) settings, similar to how this is done on other makes.
jimbo285
Jim
Fairbanks
Double? Mine beeps 8 times. The same beep as the lock / unlock but 8 friggin times. Lets the whole area know that it’s ready to be stolen
Gator 22
Florida
2021 TRD Off Road
Even without the beeps, someone sees you leave a running truck is asking for trouble.
4RunnerTony
Tony
Venice Florida
Mine will beep multiple times if something is on the rear seats. It's an alert that there may be children sitting in the back so you don't forget and leave them in the vehicle.
MTN Dew
Dave
DE
So in my gen 5 I can latch but not completely close the door and it would not beep. Have not had a need to try it in Gen 6 yet.
You can set the number of beeps and the volume in settings.
toyoda80
Beau
2025 4Runner SR5 4WD Cutting Edge
Does it honk if you use the hidden key from the fob to lock it before you walk away? My truck is at home and i am not, otherwise I could have tested.
Press the lock button on the door while inside...pull the lever to open the door...lock the door with the hidden key...walk away...please come back here to report. I'm dying of curiosity
