SR5 Quality Issues
828findadventure
Tacoma & Tundra
Yeah, I see similar on mine. I wonder if flare gasket would seal that better. A seal comes with after market flares from Rough Country etc for full size trucks. You can get it on amazon. My question is do the higher end models have the same issue, and if so what is Toyota Japan doing about it.
Undefeatable
Kevin
Southern California
Yeah, I see similar on mine. I wonder if flare gasket would seal that better. It comes with after market flares from Rough Country etc for full size trucks. You can get it on amazon. My question is do the higher end models have the same issue, and if so what is Toyota Japan doing about it.
I would have to imagine trim shouldn't matter when it comes to QC.
I feel like people think SR5 = cheapset so they care less vs TRD Pro = most expensive, so they take more time on them.
I am sure the assembly lines are the same with the difference being what crap is installed/not installed.
I could be wrong though.
828findadventure
Tacoma & Tundra
I don't think Japan works like that, but I don't work there.
Bigpaul
Poquoson Va
2025 4Runner SR5Paul
field rep told me that all other 4runners painted or black flares are made of a stiffer material ,stiffer means no bowing sr5 gets the thinner material .everyone has to put in a complaint to toyota ,they know there’s an issue but no complaints means to them it’s not important.
Undefeatable
Kevin
Southern California
That would be a shame if that is true.
well i have the painted flares. the rears are tight along the whole leading edge.
both front passenger flares are tight except around the same sharp curve point of the wheel well.
the gap is maybe a fingernail width along the leading and trailing curve of the wheel well.
this picture is facing the drivers outside rear view mirror, middle of the drivers front wheel hub
2025 2026 4runner 6th gen SR5 Quality Issues 1762390370339-mq
Bigpaul
Poquoson Va
this is a copy of the report from the toyota regional rep
2025 2026 4runner 6th gen SR5 Quality Issues IMG_5617
828findadventure
Tacoma & Tundra
So from installing Rough Country hard plastic OE flares on my 21 Tundra this is what I learned. The RC flares came with the rubber gasket to go along the top edge. When all is installed they fit flush and sealed properly. After some time, car washes and vibration they would start to come away from the fenders in places. That was even with provided rubber seals. I would then have to loosen the 10mm bolts holding them on and readjust them to sit flush. A few weeks or a month later they would start to pull away from the fenders and leave a 1-2mm gap. I just learned to live with it. The flares on the 6th gen 4Runner have clips bolts and push style pins I believe. All of those are under presure fighting each other, and this is why the flares have a wave to them. It could probably be adjusted or something trimmed internally, but I would not go to the trouble.
2025 2026 4runner 6th gen SR5 Quality Issues 458084420_10160878889817739_1868032882833779482_n
6thGen1419
Peter
New Mexico
Hello ,Iwas a proud owner of a 25 SR5 supersonic red , but now not so proud.Have had fender flare issues dealer agreed and changed flares new ones were as bad as factory ones ,dealership told me “nothing. we can do call toyota .After contacting toyota ,sending pictures and returning to dealership to meet with there regional representative they told me yes indeed there is a manufacturing defect but there is nothing they can do . Ok mad as hell but I will live with it.
Now this is where i’ve started to loose it ,have the brake squeal issue,went on waiting list for a month .Parts arrived and were replaced, brakes squealing as bad as they originally were, contacted dealership and was told nothing they can do call toyota. My first thought was here we go again , there response was take it for a second opinion, that maybe that dealership didn’t have the correct knowledge of how to fix . I politely told them we are talking about brake replacement not a lightbulb replacement, how can they not have qualified techs for that . So i’m off to find another toyota dealership.This so so sad and frustrating .Has anyone else had squealing after replacement per the TBS.
There's a TSB for the brake squeals
https://www.4runner6g.com/forum/thr...al-tsb-brakes-fix-tsb-0046-25.5534/post-91757
jayT
Banned
Banned
Banned
john
Louisiana
probably the same issue that TRD Jon had on his tacoma 4runner, fender flares not flush with the body or having ripple issues along the leading edge of the flare that meets the body.
i have the same problem with my driver's front flare. they said they will let me know something soon. it's been 1 month..lmao..telling me no without saying it directly
I have chosen not to look. So, I do not have this issue.
I have the painted flares but I have only barely taken a look at them. Like @Nodak mentioned, I believe there may be one or two specific places that there's a very slight gap, but it doesn't bother me. I suppose it will if gunk starts getting stuck in there and I feel like I can't keep it properly cleaned!
Maximus4R
Adam
Nashville
I have small gaps on my ORP, I just figured it normal with the flares being plastic and really mainly clipped on. A little scared to take a closer look now though, I don’t need my OCD kicking in making me do something stupid.
Moby
Moby
NJ
TRD OR Premium
Toyota has just lost its way. Poor workmanship and overpriced for past tense reliability
BomPho
california
4runner 2025 SR5
My brake squeal was replaced, and the squeal is less often but does happen. I brought it in and they couldn’t duplicate the sound. They informed me record it when I hear it.
Unfortunately, when it happens, it doesn’t continue so it’s near impossible to record it.
