Rear hatch window issues.
Frcefed579
51st State (jk)
Wave Maker
I'm running into an issue where I can only lower or raise the rear hatch window from the outside controls on the hatch. The inside switch isn't working at all. I tired the hold it open for 6 seconds, then closed for 2 seconds and the open for another 2 seconds to reset it, but have had no luck.
Any thoughts?
spelingbeachampeun
Michigan
2020 Navigator, 2014 MDX, 1993 Taurus SHO
If the windows are locked on the driver panel the rear window will be locked.
Not made in China
Bicycle
Good info to know.... So much in the manual to read when you have to start filtering out the stuff that does not apply to your trim level. I really which that would do a trim level manual, even a pdf.
zgreen
Zach
Ahhhhh. Same was happening for me and I was going to stop by the dealer to see what was up. Thanks for the heads up!
