Tire pressure on OEM Dunlops (4Runner Limited) – What folks are running
GrayWulf
Northern Virginia
2025 4Runner Limited
What tire pressure (cold) are you all running on the OEM Dunlop tires for the 4Runner Limited?
I just want to confirm the sweet spot for daily driving.
I always go by tge door sticker. In my case, 33 psi when cold.
I do wish they would publish a table of PSI required based on actual temperature. The term cold may be 60 deg F to some or 20 deg D to others.
if they (all manufacturers) said something like;
20 f, set to 28 psi
30 f, set to 30 psi
40 f, set to 32 psi
Maybe that is too complicated for the average driver 😎
MikeUtah
Utah
Toyota 4Runner Trailhunter
This what I use: For every 10°F change in temperature, tire pressure changes by about 1-2 PSI.
2025 2026 4runner 6th gen Tire pressure on OEM Dunlops (4Runner Limited) – What folks are running 1761934920302-ns
onlywayman
MARC
usa
2017 TOYOTA RAV4
After 12,000 miles on my limited and playing with tire pressures, I have my tires at 31 cold.
when hot they’re running at 34 PSI
THOSE DUNLOPS SUCK! I don’t think I’ll get 20,000 out of them but for now I’m burning them up🛞🛞🛞🛞😀
Love the chart. I have nit seen it before but have been making adjustment ad-hoc. So the chart is claiming 70 deg F is the temp the OEM psi is set at. Interesting.
Thanjs for sharing.
Hobb3s
2012 Jeep Grand Cherokee
33 psi cold… but mine didnt come with the dunlops i had the yokohamas on my limited for some strange reason… swapped em out for a set of Michelins, but since im at altitude the tpms shows 31 that was a fun rabbit hole to chase for a while…
Joe Dirt
ORP came with Michelin LTX Trail 6 ply .. I run mine at 38 psi cold.
i run mine at 34 psi during winter (have to keep track since it can get to -30F at times in ND), then change over to summer psi at 33. easier to keep track of now with the side pod displaying psi.
hardest part is getting my 6 gal air compressor to actually work at -20F, the oil gets so cold the compressor wont turn over. have to use my rigid battery portable air compressor i use for trips
2025 2026 4runner 6th gen Tire pressure on OEM Dunlops (4Runner Limited) – What folks are running 1762049967778-fm
