DangItsDen
DangItsDen
Hayden
The real question. Spare tire?
It'll fit. I was waiting to test these before buying one. Some dude on facebook posted a pic. It def hangs low but itll fit.
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 740601941_27997150986543175_1362465826244915444_n
BlueFinTunaGuy
Greg
Long Island, NY
2026 4Runner SR5
285/75r17 Toyo AT3 installed today. Looks muuuuch better with this suspension setup. I did notice some light rubbing at full lock reversing out of my driveway. Will get some better pics and report back on fitment after I get a chance to drive it some more.
Looks fantastic!
The rubbing must be from the mudflaps because my setup doesn’t rub and I’m not running flaps. Either way, love the way a 285/75R17 fills out the wheel well, truck looks great!
ifunlisted
AZ
@MikeD Thanks for the kind words.
Here are the parts for the two lift kits for the T4R6G.
For fitmet and labor questions and compatibility, please refer to the chart on my Trail Teams website here: https://edmartintrailteams.com/trail-teams-lift-kits/
Installation guide attached.
Hey Eric, thanks for all the awesome info on this forum! I see there's a few adjustments/modes that can be used to calibrate the TSS features to account for a change in height from a lift but another question that has come up quite a few times is regarding speedometer calibration. Is there a setting in techstream or something where you can adjust the tire size so the speedometer and tachometer are accurate with larger tires?
Noblesville IN
Website
www.edmartintoyota.com
1979 FJ40, 1988 FJ62, 1997 FZJ80, 2019 LC200, 2024 LC250
@ifunlisted Thanks! No, you can't recal speedo in GTS+ or the infotanment system. However, Lutz Auto makes plug and play harness to recal.
https://www.lutzauto.com/product-page/6th-gen-4runner-2025-speedometer-calibrator-correction-device
BPS~
Ben
AZ
6G4R
Already have Bilsteiin 6112/6100 and UCAs installed, so looking to purchase the other items in the 4R TRD lift kit (Tie Rods, Drive Shafts, Knuckles, hardware). Everything is getable except, Tie Rods. PNs PT81G-35310 & PT81G-35320 are listed as Discontinued.
Anyone know the new part numbers or how to get these tie rods?
@EdMartinToyota
Noblesville IN
Website
@EdMartinToyota
Please email me VIN. [email protected]
Fishing
New York
Can anyone share their alignment spec after the lift? This is what I have
Front:
0.0 (L) -0.1 (R) : Camber
2.7 (L) 3.0 (R) : Caster
0.04 (L) 0.04 (R) : Toe
Rear:
-0.4 (L) -0.1 (R) : Camber
0.02 (L) -0.12 (R) : Toe
-0.10 : Total toe
0.07 : Thrust angle
is my rear right toe cooked?
DangItsDen
DangItsDen
Hayden
Front:
Rear:
-0.10 : Total toe
0.07 : Thrust angle
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? IMG_3872
Front:
Rear:
-0.10 : Total toe
0.07 : Thrust angle
I literally just took this photo of mine yesterday (lift was 4 weeks ago):
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260717_063641-EDIT
I really don't understand the numbers, but I would observe that your right rear toe is not too different than my left rear. OTOH my thrust angle is spot on zero, yours a bit off (but just a small bit and I don't know what is too much).
I am experiencing left front tire rub after the lift (with my 35s) that leads me to believe my caster might have been overdone slightly - anyone know if it can be adjusted back a degree or so without wrecking the overall alignment - and maybe gaining a fraction of an inch of clearance in front of the tire? (And please educate me if this is a dumb question.)
josiahg52
Josiah
Front:
Rear:
-0.10 : Total toe
0.07 : Thrust angle
No. Thrust angle is 0.07, which is tiny. Rear toe isn't adjustable anyway.
josiahg52
Josiah
I can't see your sheet (on my phone) but technically, less positive caster may provide the clearance. Altering that will also affect the rest of the alignment, definitely on that side. The shop should be check my the rear numbers in order to inform the front alignment and ensure the vehicle tracks straight.
