On Road Ride Quality - TRD Off Road vs TRD Pro
JR_Ontario
Ontario
Lexus NX
Hello group,
I have not been able to find a TRD Pro locally (to test drive). I was able to drive a TRD Off Road, and felt the on-road ride was quite harsh. Has anyone driven both? How does the TRD Pro compare (on road)?
Thanks in advance!
AF VETERAN
Frank
Delaware
25 4Runner TRD ORP Hybrid Heritage Blue, 22 Jeep Overland, Black
Over inflated tires seems to be a trend when people pickup their 6th Gen, mine was.
Duframer
dave
subaru ascent
Check the air pressure. My wife’s Limited rode rough too. Rode a lot better after I let 20psi out of the tires. ?
What are you riding it at?
zgreen
Zach
Hello group,
Thanks in advance!
Hey there. I have a Pro and it rides like a dream on the road. There are three different suspension settings, with one being the softest three being the hardest I believe. I prefer two and it is pretty awesome. I have no complaints at all.
Sam
Illinois
BMW X7, Tesla model 3
I bled around 5psi from my ORP tires after I took delivery of the vehicle. At low speeds the road feedback is lot more than when its 50+ MPH. Drove at 80+ speeds for long duration and the ride quality was just great. Also on gravel and trails it was awesome.
Lotzof4Runners
Bill
Seattle, WA
I'm running 285/70R18 E-load BFG KO3s.. It rides horrible, but I dropped the PSI to 33lbs and it's better. Certainly not a dream. After hearing about the suspension mode adjustments features on the TRD PRO, I'm now curious and want to know more.
Lotzof4Runners
Bill
Seattle, WA
Very curious about this. Can you please give us a little more? Is the setting a button, or is the setting electronic on the digital gauge cluster? If it's on the gauge cluster, could you post some photos of where the setting is? I know it's a PRO thing... Want to do a little investigation on this.
Thank you kindly.
Dead Horse
Oklahoma
Thank you kindly.
It's on the shock.
2025 2026 4runner 6th gen On Road Ride Quality - TRD Off Road vs TRD Pro 1749926834564-z8
Lotzof4Runners
Bill
Seattle, WA
Thanks for posting that photo. That's not what I was thinking. I was thinking it was something that could be adjusted inside the cabin - maybe something buried in all of those settings. I want to drive a PRO now to see how the different rides feel.. Can't wait to ask the sales person about this, and then have to climb under there myself to change the setting for the test drive. :rolleyes:
jcash25
jason
Houston
2025 TRDO Premium
Bro.. you put the stiffest sidewall E rated all terrain 10ply tire on a 4runner. You usually put E rated tires on heavy duty trucks that haul and tow large amounts of weight... That is why you have a horrible ride now.
I had BFGs KO2 and 3s on my 08 3/4ton cummins and loved them also helps with sidewall cuts and scrapes i used to deal with. I also put them on a 1\2 ton 4wd chevy and i could feel the weight and more noticeably the ride got a lot rougher due to the tires to the point shocks wont help. Those are solid tires Im just not sure the need for E rated tires on a 4runner.
BonRunner
2026 TRD Sport Premium / WCP
Unfortunately, most popular tires for 18" wheels in aggressive size are E-load.
jcash25
jason
Houston
2025 TRDO Premium
Well if you're needing that "look" then don't cry about the ride and noise....you see what popularity gets you.
BFG makes a KO3 285/R60 D load tire 8ply and a 265/R70 D load that should give you a better ride...But he's goin for looks over use. He should be airing down to off road not make the daily drive better(which it didn't).
