DangItsDen
DangItsDen
Hayden
Did you ever get the brakes squared away? I ask because before I bought my 4runner, I had a 25 Tacoma that I lifted on Bilsteins. After the lift, my brakes became very very spongy. Part of me wondered if it was the heavier wheels and tires I added, but I honestly don't think that was the cause. I don't have the truck anymore but I'm curious if you found the issue.
I am still not sure if its just a change in the nose dive from the higher front end that's making me feel like something is different. It's not drastic enough for me to think something is really wrong, but I am definitely going to have the dealer look at my brakes "for no particular reason" next time I take it in... I'm also keeping a close eye on brake dust build up on the fronts to see if it increases.
Best way I can describe how they feel is when stopping, it starts kinda of normal, then about half way through the braking cycle it feels like its grabbing more and more quickly before coming to a complete stop. Like its not totally linear if that makes sense.
JD013
New Jersey
2026 4runner
That makes sense. Mine felt like they didn't have the same "bite" as before and the pedal had a much spongier feel to it. The truck still stopped, but I was never comfortable with the brakes whatsoever. I questioned how the lift could have triggered these issues, but something definitely just wasn't right.
DangItsDen
DangItsDen
Hayden
Yeah what likely happened is that the brake like got stretched during install and that introduced bubbles to the brake line. A bleed would probably fix it
JD013
New Jersey
2026 4runner
That's probably the case here, and was with mine as well.
Lift completed! Will provide detailed measurement comparison and resultant ground clearance numbers at some point but for now, here is a cluttered view of the take off parts.
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260621_144745
Tie rod end is a just a bit longer (BTW axel and rear springs are notably longer... will cover in future post.)
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260621_165031
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260621_174602
Ride's great - but I can't tell much difference from stock. Could be I'm just not sensitive enough (I never though the stock TRD OR ride was bad, like many here do.) So far doesn't seem like much impact on MPGs - but I will be tracking and reporting details on that in the Hybrid milage thread.
More photos and number to come later....
FWIW, I am not noticing anything different about the braking from before the lift was installed.
OTOH, after driving for a few days I am now noticing some "smoothness" vs. the stock TRD OR suspension - especially when going over small speed bumps (e.g., in a parking garage) its less "acute", maybe "softer". My wife noticed a difference so it must be true:>)
mfoga
r4unner
I asked at a local dealership when I had 5k service done they want $2600 to install.
kcle730
Kevin
Website
www.instagram.com
2025 4runner trd offroad premium
Just put my order in for the lift. Questions for yall. Did you need to refill or top off the diff oil after replacing the axles?
josiahg52
Josiah
You're talking about the front CV axles? No, the differential fluid is completely unaffected. You will not touch any fluid at all.
Check out the installation instructions that were posted earlier in the thread. The diffs are not touched IIRC
kcle730
Kevin
Website
www.instagram.com
thanks guys for helping! I read the instruction manual and found out you do need to refill the diff fluid. The front axles goes into the front diff. That’s why.
But all good! Got new fluid! And it’s done!
Love it! Feels very nice!!
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? IMG_6225
josiahg52
Josiah
You had to "refill" the differential? Surprising.
josiahg52
Josiah
Browndirtcowboy
Steve
Valley Springs, CA
2026 TRD ORP 4Runner, 2019 Tundra, 2026 XSE rav4
Just got the TRD 2.5 inch lift completed 5k out the door. The labor was 1900 with the kit running the typical 2999. I found the lift on sale from a dealership in another state for 2490 but after the shipping was added at 470 it ended up not being worth the risk of the shipping. Didn't want to worry about damage and the hassle of dealing with any returns. Threw the methods and the 285/70/18 Falken wildpeak At's on that I had on the 25 Land cruiser and I do have some minor rubbing. The LC250 had the wheels and tires on it stock with zero rubbing and that was on full flex off road. So the wheel clearance on the Land cruiser is much better even with a 2.5 inch lift on the 4runner.
The height is 39 1/4" in the rear and 39 3/4" in the front. Was hoping it would settle but after 200 miles it's remaining the same on the tape measure. Not a big fan of the stinkbug look but it rides nice. I figure after a front bumper and winch that number will then come down.
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 4runner 2.5 lift
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 3 quater view lift (2)
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 3 quater view lift (1)
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260504_151654
