josiahg52
Josiah
Just back from Discount Tire, and I have to say -- this really is a new generation of A/T tire.
These ride and steer noticeably better than the Dueler A/T Ascents I took off.
Steering response is excellent, along with the low weight and excellent dampening means it rides better over bumps and expansion joints than expected.
I feel warranted in my decision to get rid of the Duelers in favor of these, and I'm definitely excited to see how they perform on the trail.
Size LT275/70R18 E Load
They look good, too! It'll be interesting to see how they wear, but also if there's a substantial or noticeable fuel efficiency hit.
My 265/70R18 short list
Nokian Outpost nAT (E or SL)
Mickey Thompson Baja Boss A/T (alternate size, no OE fitment)
Toyota Open Country A/T III (E or SL)
Pirelli Scorpion XTM AT (LT, E))
clk55r1d3h
los angeles
2026 4runner
The EV version is SL rated, which means it's just slightly lower rolling resistance.
https://www.tirerack.com/tires/tire...i&tireModel=Scorpion+XTM+AT&partnum=77SR8SXAT
If you're doing any serious off roading, you want E load.
C and D load are basically non-existent in 18" size since the KO3s won't be made in that size and ply.
Ya I’ll be going with 17s for that reason but even then I couldn’t find SL load for the pirellis. I won’t be doing anything serious and SL is good for me. Save on weight a little too.
josiahg52
Josiah
It's odd, when I put 17" American Racing Mojave wheels on my 2001 Tahoe in the early 2000s, there were hardly any 17" tires it seemed. No longer the case. I need to do something with those wheels, they're the black Teflon(?) coated ones.
yotahilux
Chuck
Harrisonburg, VA
2021 JLUR, 2023 Outback Wilderness (2BSold), Enroute 2026 4Runne Off Road Prem
Nokian Outpost nAT 255/75 R17 has a diameter of 32" and weight of 41.9 lbs - $207 in Walmart
Nokian Outpost nAT 265/70 R17 has a diameter of 31.6" and weight of 40.8 lbs - $182 in Walmart
As a note, the 265/70/R18 is 32.6" per Discount Tire with a weight of 46 pounds.
jcash25
jason
Houston
2025 TRDO Premium
I've been shopping for new tires for awhile and was interested in how the Pirelli Scorpion stacked up against some of the most tried and true tires.
Looks like tyre review just dropped their results on 8 tires
Tires tested:
Nokian Outpost nAT
BFGoodrich All-Terrain T/A KO3
Goodyear Wrangler DuraTrac RT
Nitto Recon Grappler AT
Falken Wildpeak AT4W
Westlake SL369
Pirelli Scorpion AS Plus 3 (all-season r
eference)
Article
https://www.tyrereviews.com/Tyre-Tests/Best-All-Terrain-Tyres-2026-Test.htm
Video
AI summary:
This comprehensive review by Tyre Reviews spans a year of testing across Northern Europe (snow/ice), Central Europe (dry/wet), and Utah (off-road dirt handling). The test evaluates six of the newest, most aggressive all-terrain (AT) tires, one budget mild-AT tire, and a standard all-season tire as a reference point.
The test vehicle used is a Ford Ranger Raptor, mostly evaluated in rear-wheel-drive (RWD) mode to push the tires to their limits.
1. Dirt Handling & Off-Road Testing
Tested on a mix of rocky, smooth, and fluffy dirt surfaces in Utah.
  • Pirelli Scorpion All Terrain Plus (XTM AT/AT80): The top performer alongside the Nokian. Easiest, most predictable drive with a well-balanced grip circle.
  • Nokian Outpost NAT: Matched the Pirelli for the best subjective driving feel; excellent carcass compliance over bumps and great bite in loose fluff.
  • BFGoodrich All-Terrain T/A KO3: Highly impressive. Even though it's a stiff, heavy tire, its carcass was incredibly compliant in the ruts. It performs slightly better under straight-line braking and acceleration than it does while turning.
  • Goodyear Wrangler Duratrac RT & Falken Wildpeak A/T4W: Both offered good mechanical grip, but their stiff carcasses caused them to struggle and bounce when hitting heavy ruts. The Falken suffered from noticeable understeer.
  • Nitto Recon Grappler: Had decent straight-line braking grip, but very poor lateral (side-to-side) grip. The rear end would step out rapidly and unpredictably on throttle.
  • Westlake SL369 (Budget/Mild AT): The most difficult tire on the dirt track. It had decent rubber compound grip on smooth sections, but its weak carcass provided zero stability through rough ruts.
  • Pirelli Scorpion AS+ 3 (Reference All-Season): Performed surprisingly well on hard-packed dirt because its lighter weight and compliant carcass didn't have to account for extreme puncture resistance. However, it struggled to recover once sliding and would fail completely in deep mud.
2. Wet Performance & Braking
Wet handling was tested on a 2-minute lap. Wet braking and hydroplaning resistance were measured objectively.
  • Pirelli Scorpion XTM AT: The absolute standout. It was an astonishing 5 seconds faster per lap than the Westlake and roughly 10 seconds faster than its premium rivals. It transformed the truck's dynamics, offering immense traction, crisp steering response, and top-tier wet braking.
  • Westlake SL369: The surprise runner-up in the wet. Because its design is biased toward on-road driving (milder tread), it cleared water effectively and felt sharp on the brakes.
  • Nokian Outpost NAT: The fastest of the remaining premium pack. It resisted terminal understeer and allowed the driver to rotate the truck smoothly using the throttle. It also won the hydroplaning resistance test.
  • BFGoodrich KO3: Excelled at straight-line wet braking but heavily disliked cornering, exhibiting continuous, safe (but slow) understeer.
  • Goodyear Duratrac RT: Felt "industrial" and required a lot of steering input. It had a wide recovery window but lacked structural sharpness.
  • Falken A/T4W & Nitto Recon Grappler: Finished at the bottom. Both suffered from low grip, poor braking, and a "peaky" rear end that would suddenly snap into oversteer.
3. On-Road Comfort, Noise & NVH
Evaluated over a full day of driving across varying pavement types in Utah.
  • Nokian Outpost NAT: The biggest surprise on the road. While it didn't strictly dominate one single area, it combined steering sharpness, low noise, and excellent ride damping perfectly, making it the host's top recommendation for a daily driver.
  • BFGoodrich KO3: The most plush and comfortable tire. It rounded off harsh bumps beautifully. However, its steering in this specific size felt sluggish and unpredictable, causing a delayed "two-part turn" reaction between the front and rear axles.
  • Pirelli Scorpion XTM AT: Possessed the sharpest, most stable steering and best shoulder stability (feeling like a sports tire), but rode slightly firmer and louder than the BFG.
  • Goodyear Duratrac RT & Falken A/T4W: Both felt agricultural and a bit bouncy. The Falken was noticeably loud at highway speeds and suffered from poor damping over bumps.
  • Westlake SL369: Noticeable drop-off in refinement. While total volume wasn't terribly high, it emitted an annoying high-pitched pitch reminiscent of a failing wheel bearing and held onto vibrations.
  • Nitto Recon Grappler: The loudest tire on test. It produced a traditional, prominent all-terrain "hum" at speed that modern premium tires have largely engineered out.
4. Snow Performance
A brief overview ahead of a full upcoming winter test video.
  • Goodyear Wrangler Duratrac RT: The objective king of the snow. It produced the fastest handling lap, best braking, and second-best traction.
  • Pirelli Scorpion XTM AT & Nokian Outpost NAT: Right on the Goodyear's heels. The Pirelli had slightly better traction but slightly worse braking, while the Nokian was incredibly solid overall.
  • BFGoodrich KO3: Very competitive and performed reliably in both 2WD and 4WD configurations.
  • Falken A/T4W, Westlake, and Nitto: Considerably behind the pack. The Falken A/T4W was uniquely disappointing, with snow traction sitting 30% lower than the leaders. The host explicitly warns against using it in heavy winter climates.
Final Standings & Summary
PositionTire ModelKey StrengthsKey WeaknessesFinal Verdict
1st PlacePirelli Scorpion All Terrain Plus (XTM AT/AT80)
  • Dominant wet braking
  • Fastest wet & dirt handling laps
  • Top-tier snow traction
  • Exceptionally sharp steering
  • Slightly firmer ride quality
  • Slightly more road noise than the softest options
The Winner: Represents a generational leap for the AT category. Delivers sports-tire handling on pavement while dominating off-road and winter testing.
2nd PlaceNokian Outpost NAT
  • Best overall balance of manners
  • Extremely low road noise
  • Superb winter/snow grip
  • High hydroplaning resistance
  • Slightly longer raw braking distances in dry pavement conditions
The Best All-Rounder: A masterfully engineered package with zero glaring flaws. Easily the top recommendation for an everyday daily driver.
3rd PlaceBFGoodrich All-Terrain T/A KO3
  • Unmatched plush ride comfort
  • Excellent impact damping
  • Stellar straight-line braking
  • Great compliance in dirt ruts
  • Heavy understeer in wet corners
  • Sluggish, delayed "two-part" steering response on-road
The Comfort King: Sturdy and premium over rough bumps, but sacrifices pavement handling agility and cornering speeds.
4th PlaceWestlake SL369 (Budget)
  • Strong wet road braking
  • Predictable on-road handling
  • Very low retail entry price
  • Weak carcass struggles in ruts
  • Poor winter snow traction
  • Emits an annoying, high-pitched highway drone
The Wild Card: Road-biased design punches well above its weight class on wet/dry pavement, but falls short in severe off-road terrain or real winter weather.
5th PlaceGoodyear Wrangler Duratrac RT
  • Undisputed king of pure snow
  • Fastest snow handling & braking
  • Tough, durable carcass in dirt
  • Mediocre wet pavement grip
  • Unrefined "industrial" handling
  • Noticeably bouncy ride quality
The Winter Warrior: A traditional, heavy-duty all-terrain tire built to survive harsh jobsites and deep winter conditions, sacrificing daily street refinement.[/TD>
6th PlaceFalken Wildpeak A/T4W
  • Excellent dry braking metrics
  • High tread life and wear resistance
  • Terrible snow traction (-30%)
  • Heavy understeer in dirt
  • Prone to sudden wet oversteer
The Disappointment: Sacrificed too much performance and winter traction in favor of longevity. A massive step down from the celebrated AT3W legacy.
7th PlaceNitto Recon Grappler
  • Decent straight-line mechanical braking on dry dirt tracks
  • Worst wet handling and braking
  • Unpredictable, peaky breakaway
  • Loud traditional highway hum
Last Place: A legacy 2021 platform that simply can no longer keep pace with modern rubber compounds and modern tread architecture.
Its spelled.....TIRE.... In America
jcash25
jason
Houston
2025 TRDO Premium
Its not ODD factory wheels for Tahoes and all GM trucks and suvs back then were 15" wheels with some 16" also. So the number of tire makers making 17" tires would be maybe 2 companies if not just one and the sizes would be very few to choose from.
My first truck was a 1993 stepside chevy with factory 15" wheels. 18" wheels were all the rage and most expensive at that time up until they started making 20" wheels. There were very few sizes to choose from in tires back then, most were made for factory size wheels.
Geez thanks for making me feel really freakin old having to explain that....
josiahg52
Josiah
Yes, 16" factory, 17" were the Z71 option back then, GMT800 days.
BonRunner
2026 TRD Sport Premium / WCP
Is there any reviews on the mid-tier Cooper Discoverer Road+Trail AT? i'm running 265/70-R47 on my SR5, stock rim & height, no rub. it's like the sweet spot, imho. it doesn't feel heavy and no noticeable drag during acceleration. Designed for more road and some trail, no significant noise at 120kph. Also, it is 3MPSF rated so should be good for this coming Alberta winter - remains to be seen.
Here's latest pic of "Shadow", my SR5 in Underground color, hence the nickname.
I had the Cooper Discoverer Road & Trail AT previously on stock 20". Ride wells in highway but sucks on ice/snow even in low speed.
Now I run Falken Wildpeaks AT4W on 18". Much better performance.
2025 2026 4runner 6th gen Best A/T Tires Review: Scorpion All Terrain Plus, Nokian Outpost NAT, BFG KO3, Westlake SL369, Wrangler Duratrac RT, Wildpeak AT4, Recon Grappler New Tires_02
2025 2026 4runner 6th gen Best A/T Tires Review: Scorpion All Terrain Plus, Nokian Outpost NAT, BFG KO3, Westlake SL369, Wrangler Duratrac RT, Wildpeak AT4, Recon Grappler 20260605_181609
Shadow4r
Lorenz
6th gen 4Runner, 3rd gen Rav4
Darn. I thought i saw reviews that snow handling was good. Alberta winter is harsh.
The Cooper had 3MPSF snow rating. Thank you for your owner review, at least i will be more careful this coming winter. Thanks 🤟
josiahg52
Josiah
The Cooper Discoverer AT3 XLT E were good in all the southern Maine weather on my Ram truck. I'm looking for something lighter, Ithink, but I'd run them again.
NE Oregon
2026 4Runner TRD Off Road
I’ve been very pleased with Cooper, and once the Falkens on my 4R need replaced, I’ll look at the new generations of Coopers to see how they rate against other brands.
I’m also in snow country, although last winter was pretty much snowless at my elevation. I will be buying Bridgestone Blizzaks and a set of wheels to mount them on. Any recommendations on best places to buy? Here in NE Oregon, Les Schwab’s is our goto tire dealer, but they don’t carry Bridgestone. For the record, Les Schwab has a well earned superb reputation.
Tarekith
Upper Left US
4Runner ORP & ‘22 Tacoma OR
I got my Blizzaks at Tirerack.com and had them shipped to a Discount Tire here in Central Oregon for the install. Same company FWIW.
BonRunner
I'm in Montana, just a few hours south of you and our winters are mostly the same.. I remember one time with the Cooper in icy parking and it was slipping hard pulling out of the parking lot. End up switching to 4LO and maneuvered out slowly. They were decent if you have momentum and traction on roads, but i'd be careful at dead stop.
Jafo
Lino
Florida
2024 Chevy ZR2
How are they on the highway? Looking to replace my Falkens AT3s with something smoother.
CO/ZA
Denver
25 4R ORP
How's the road noise ?
There's not really any noise until you reach 50mph, then there is a bit.
It's only a hair louder than the Dueler Ascents, and that is very impressive for a more aggressive A/T tire.
I would go along with saying that they're about the same as KO3s.
EDIT: Having some trouble with 3/5 of what I bought, 3 of them are unable to balance - with one having around 60lbs of force that is unable to be resolved. Tire Rack is doing a quick turn around of 3 tires under Pirelli satisfaction warranty. Tires are great otherwise!
