FloridaPhotog
Jon
SW Florida USA
2026 4Runner
Drained and refilled the front and rear differential on the 4Runner today, it had 5529 miles on it. I decided to not use OEW gear oil and opted for Amsoil 75W85. I was shocked on much fine metal was on the magnetic drain for the rear differential. The gear oil was dark black. The front probably didn’t need drained but I like to get the break-in oil flushed out before 7,000 miles.
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) IMG_0703
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) IMG_0704
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) IMG_0707
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) IMG_0709
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) IMG_0711
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) IMG_0715
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) IMG_0717
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) IMG_0719
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) IMG_0720
Snowball
2026 Toyota 4Runner
I did the same thing (but with Redline fluid) at 5k miles and had a pretty similar amount of particles on the magnet.
YotaMerchant
2025 4Runner SR5 4x4
doing mine this afternoon, decided to wait till 15k miles and hopping i dont regret that but i havent towed since i got it a year ago. did you have to drop spare tire to do Rr?
FloridaPhotog
Jon
SW Florida USA
2026 4Runner
YotaMerchant
Fishing
New York
Three of the "12157‑10010" (silver) fill and drain for rear and fill for the front
and the front uses "90430‑24017"(copper) for drain.
Wait so is the bottom ones the old ones? they all look the same
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) 1781546711243-l
Joe Dirt
How come no one's talking about the transfer case fluid. That requires a lighter grade.
I'll probably do 15 to 20K change all soon.
FloridaPhotog
Jon
SW Florida USA
2026 4Runner
The transfer calls for 75W. The dealership I talked with said they put the same weight in all three holes. That being said my research found that the transfer case calls for GL-4 and stated that
GL-5 has some reacton with yellow metals. However, some say modern GL-5 won't harm yellow metals. The Toyota spec call for GL-4 for the transfer case so that's what I went with.
Joe Dirt
I'm going with Ravenol (pick included) they make a specific oil for our transfer cases.
For sure there is different Metallurgy going on in the transfer case. .
These transfer cases need a very light specific oil so they work properly.
Thanks for the feedback
2025 2026 4runner 6th gen Front & Rear Differential Fluid Changed / Serviced (2026 4Runner 6th Gen) 20260615_155613
Snowball
2026 Toyota 4Runner
I did the transfer case at the same time, and it was by far the cleanest of all the fluids.
I’ve been running 75W-85 GL5 in all three since my previous Tacoma and plan to do so in the 4R as well.
Supposedly the Redline GL5 doesn’t have the harmful stuff that damages brass like the older GL5 formulations, and that is only really a concern in manual transmissions with brass synchros anyways.
To each their own though.
Also, you don’t have to drop the spare tire to do the rear diff (I didn’t), but hindsight it probably would have made it much easier. Especially since you’re putting quite a bit of fluid in there.
SteveS
Steve
Puyallup, WA
$1500 - OUCH. That is nuts. What was the $1500 consisting of, or what was the breakdown in parts vs labor?
Google's AI reported $400 - $700. Not that I trust anything AI.
