Are you gutsy enough ? Back window switch reversal
so, the back window switch seems to defy logic. press up to make window
go down, pull down to make window go up.
Well, if you drop the overhead console box the switch is direct connected
to the PCB, so not easy to make a change.
The connector though, is accessible. Anyone brave enough to flip
these pins 20 and 19 and make the switch operate like some of us think it should ?
Pull down, window down, push up, window up.
2025 2026 4runner 6th gen Are you gutsy enough ? Back window switch reversal 1780517045733-60
2025 2026 4runner 6th gen Are you gutsy enough ? Back window switch reversal 1780517264569-mh
NOTE: 20 and 19 are test points, there is no wire there
the actual wires/pins to flip are 22,21
21 sky blue - down
22 pink - up
quadna71
Delaware
2025 4runner
Curious....but not sure I want to drop the panel just for the switch. Now if I had to drop it for other stuff then I'd likely consider it.
I'm with ya, one of the first things that bugged me, kinda usto it now...
HVLA
Lexus
Easy to do. Just flip the wires. Tundra guys have done it.
PearlyGates
Shane
AL
I just replaced the map lights with the Meso light and contemplated switching the wires during that process but I didn't pull the trigger. I may have to try it!
Joestac
Any wires to switch to get the dang hatch to open via power assist with the window down?
moosepwr
Waxhaw, NC
2025 TRD Offroad Premium XSeries
It makes sense in my mind. I've driven or ridden in many cars with a "lever" window button, as opposed to a "switch" style toggle. The lever style was always pull for up and push for down.
But I can see how it can be confusing to some.
HVLA
Lexus
I believe you would do it at the plug in the liftgate.
HVLA
Lexus
Weight is the issue most likely. Would need a much stronger motor to account for the leverage added with window further away from liftgate hinge.
that's part of it
the other part is if window was down, there is a big chance something
is sticking thru the window opening, and if the gate raises or lowers
with something passing thru the opening, some type of damage might occur
HVLA
Lexus
that's part of it
Could be.
I'm planning on doing it soon, I have an SST P/N: 09991-00520
and this has been bugging me. If I fry my 4runner so be it.
