romik
Romik
2025 Toyota 4runer
Hey everyone, just wanted to share my truck! Upgraded to Bilstein 5100 front and rear shocks, and I’m really happy with the height and the ride.
Feel free to chime in on the alignment numbers if you know your stuff.
2025 2026 4runner 6th gen SR5 Suspension Lift: Bilstein 5100 35118-44b76f4a522fb51b47044e4a2e586943
2025 2026 4runner 6th gen SR5 Suspension Lift: Bilstein 5100 Alignment Specs
JDH3
James
Seguin Tx
Tacoma TRD off road 4runner Trd road
Hey everyone, just wanted to share my truck! Upgraded to Bilstein front and rear shocks, and I’m really happy with the height and the ride.
2.2 inch front and 0.8 rear lift. Sweet spot considering my tire size and overall level stance!
What's the part number for the shocks?
ah4rsr5
Abraham
VA
2025 4R SR5
which bilstein shocks? did you leave the springs the same ? How is the ride compared to OEM ?
romik
Romik
2025 Toyota 4runer
5100 dedicated for 6Gen. Stock springs.
I would say its a bit firmer, more controlled, less body roll for sure which i love it, less nose dive under breaking, and the most important thing in my opinion you get more droop travel compared to any preloaded collar lift, less bouncy and more truck like ride... Very satisfied overall.
4running
TX
2020 4Runner SR5
Great lift height and leveling amount! What size are your tires?
Daronc
Daron
Santa Clarita, CA
Nicely done
Part numbers:
Front: 24-347464
Rear: 24-347433
Nicely done, great stance!
Mine are being installed on June 5th, can you please measure from the center of the wheel hub to the bottom of the fender flare so I can see what actual lift you got, thanks!
2025 2026 4runner 6th gen SR5 Suspension Lift: Bilstein 5100 IMG_0516
romik
Romik
2025 Toyota 4runer
Nicely done
Center cap wouldn’t be very accurate, so I went with the lower cap/point since I can hook the measuring tape there. It’s 24 1/8 inches.
BlueFinTunaGuy
Greg
Long Island, NY
2026 4Runner SR5
@romik Are you running Westcott pucks in the rear to achieve the 0.8” lift?
My install is 6 days away, I’m doing Bilstein 6112/6100 combo with rear Westcott pucks ( 2.4” front, 0.8” rear) current rake is 1.8” so was looking to bring everything up to about 2.5”.
Going for 285/75R17 BFG AT KO3s with 1” spider spacers. Gonna be sick, I think lol
romik
Romik
2025 Toyota 4runer
That’s right. For your setup, I would recommend a 1-inch ReadyLIFT spacer for the rear if you like a level stance. And i would avoid any wheel spacer, that's just me.
BlueFinTunaGuy
Greg
Long Island, NY
2026 4Runner SR5
Thank you, I already have the Westcott pucks so if circlip setting 4 (2.4" for SR5) on front 6112s is too high then I'll have to drop it down a size to the (2" lift), I like many others would prefer a lift with a small factory rake than a dumpy bottom.
I don't like the idea of spacers either trust me. I'm trying to do something not seen too often which is fit 285/75R17 on my stock +55mm offset SR5 rims, Just worried that the (33.8" x 11.2" KO3) will rub on the stock UCA.. So I bough 1" spiders to give me a ~30 mm offset which should work.
I should just scrap the SR5 rims and spacers and get BlK RHINOS, that's the move lol
2025 2026 4runner 6th gen SR5 Suspension Lift: Bilstein 5100 black rhino-alta-br033-matte black-17x8-2025 toyota 4runner 10
BlueFinTunaGuy
Greg
Long Island, NY
2026 4Runner SR5
Soo, I decided to scrap the whole 1" spider tracks paired with the SR5 rim to try and fit the 285/75R17 K03. My mindset lately has shifted to how to best naturally fit a 285/75R17.
Ordered some Method 703's 35 offsets. lol
Twisted
5th Gen TRD -> 6th Gen TRDORP
For what it is worth, I'm using the 6112/6100 setup, fronts set at 2.4", and a 1" Cornfed spacer in the rear. (The Westcott is nice but billet is way overkill for this part that you'll never be able to see. Cornfed is half the money and been in the game a long time.) I've got a drawer system in the rear with some weight in it and I'm sitting level. I'm on 285/70/17's but a 0 offset and I've got no clearance issues.
