ngfilla94
Nathan
St. Peters, MO
2025 TRD Sport Premium
**Updated with Installation photos**
Also see official instructions (posted by @brumey):
https://www.4runner6g.com/forum/attachments/mug-guard-install-guide-pdf.13056/
My OEM wide mudflaps (Pro and Trailhunter version) ordered through Olathe Toyota got delivered today. Instructions are available via TIS. Does anyone have access that can share them? Will update the post with a short writeup and installation photos for anyone else doing the same or considering.
Installation is pretty straightforward for the fronts. The TIS guide is easy to follow (provided by @brumey below). Turn the front wheels all the way one way for easy access. Rears were a little bit more involved, but not by much. The TIS instructions tell you to drill two holes in the liner and bumper tabs. The only way to do this is to remove the wheels, which is not worth the time IMO. @Vincenzo has done this install and used a hot coat hanger to melt holes. I opted for a deck screw heated by a propane torch since it was closer to the 3/16" hole you're looking to make. I marked the holes with a paint pen. I also opted to remove the whole inner liner to melt the holes. It's just removing 3 extra clips than youve already removed. Total install time was less than an hour. The wide flap option is a good fit if you're looking to go with a bigger tire like I did, or a wider offset wheel. For a little over $100, hard to beat.
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250502_185653
Currently $108. Available here: https://parts.olathetoyota.com/oem-parts/toyota-4run-mudg-trd-pro-bl-pk38935s10tp
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_122710
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_123111
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_123330
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_125701
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_125921
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_130052
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_131042
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_130512
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_131032
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_131123
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_131509
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_131659
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_133550
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_133607
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_133601
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_133525
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_133513
2025 2026 4runner 6th gen OEM Mudflap / Mud Guard Install Guide DIY Instructions [Photos & Installation PDF] 20250503_133540
Official installation instructions:
Vincenzo
Southeast
I deviated slightly on the instructions. Because space is tight. I used a coat hanger heated with a flame to burn a hole instead of drilling on the rears.
ngfilla94
ngfilla94
Nathan
St. Peters, MO
I do recall seeing that mentioned on another thread. Depending on how much time I have tomorrow, I may opt to remove the wheels.
JR1
Joe
Missouri
That is your best bet. I have a right angle drill with a short bit. It only takes a few minutes to remove the rear wheel if you don’t have a right angle.
Joed
Joe
Washington State
2025 4Runner TRD ORP
Thanks so much, ngfilla94. I installed a set on my 2025 TRD ORP and I really found your thread useful - especially the installation instructions from Toyota. Thanks again!
milsuper
VA
2026 TRD Off-Road Premiun
I installed same style Toyota OEM mud guards for my 2026 Tacoma, and it was much easier with pre-existing grommets/fasteners that you can directly place screws into. I wonder why they made it more difficult for 4R.
Thanks for the photos!
dealsbarknife
Alberta, Canada
4runnee
How hard would it be take them off? My 4Runner came with these flaps from the dealer. They seems extremely rigid and I feel like they will catch while off roading and rip out the bumper.
milsuper
VA
Not very difficult to take them off at all (vs. it takes a bit more time for install). You may want to get some extra push pins/grommets to fill few holes if there's any void. Also, you may need two plastic brackets for front mud flap areas. Otherwise, the existing screws...you just put them back in the same spot. If you have a right angle drill bit adapter (on an impact driver), either the install and removal can be done in about 30 minutes (For installation, I did not even have to jack up the 4R, turn front wheels, or remove the tires).
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
backtoblack
4RUNNER SR5
Anybody have the Toyota part# for this piece? I wanna remove the OEM mud flaps and cover up the hole after the removal with this OEM cover piece.
Mine came with OEM mud flaps and I was never given this cover piece by the dealership.
Thanks!
pmedicj
MA
Thanks!
I just installed a set on mine and was going to take a picture of the part numbers on the back in case I wanted to remove them at some point but forgot.
Note: on the front there is a small rubber trim piece, grommet and 3 screws that gets taken off, discarded and replaced with the mud flap hardware. If yours came with the flaps you might also be missing these pieces. If you look at the install instructions on post #2 you’ll see the parts I’m talking about.
