dalc90
Daniel
Miami
6th gen 4Runner
I installed bilstein 5100 on my trd sport yesterday with stock coils
Lifted up to the 5th ring that is 2.2"
It rides better then the stock suspension now
No lift at the rear
Now my front sits .25 higher then the rear my next plan is to install 5100 rear suspension to level up the truck
It looks pretty much leveled right now but when you sit inside you can feel the rear sag
Is this a RWD? Would you say the ride feels ‘plusher’ than before?
aj negi
Ajay
Calgary
Its 4wd
There is not a drastic change in the ride
But I would say it rides better now then the stock suspension
Daronc
Daron
Santa Clarita, CA
I received and installed the Bilstein 5100 suspension on our 2025 4Runner Limited this weekend. The Limited had a rough ride from the start. You could feel every bump in the road. I had installed the Westcott preload lift front and rear and that didn't make it worse but it sure didn't get any better. So, I left the .75 inch spacer in the rear and installed the 5100s there. I removed the front collars and spacer and installed the 5100s set at 2.2 inches. Install was overall pretty easy. Hardest part was disconnecting the darn AVS connectors. I was concerned I would get warning lights on the dash but we've driven it about 75 miles and still no issues.
The ride is sooo much better. An added bonus was that we had always had a rattle in the rear every time we hit a bump. Now, it's so much smoother it got rid of the rattle. I forgot to add that we had already ditched the stock 20s and switched to the 17"methods with 265-70-17 BFG KO3s. That didn't help the harsh ride either. With this setup it is almost dead level. From floor to front fender is about 37.25 front and 37.5 in the rear. Was 37.5 all around with Westcott. I like the very slight rake better.
No lift at the rear
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 20260508_112347
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 1000010325
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 1000010322
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 1000010323
No lift at the rear
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 20260508_112337
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 20260504_120948
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 20260504_121009
Very nice set-up! Can you please measure from center hub to the bottom of the fender well. I appreciate it.
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) IMG_0516
dbrock34
Dean
Indiana
2025 4RUNNER Limited
Finally got around to measuring this for mine. It's sitting at 23.0 in the front and 23.25 in the rear.
Daronc
Daron
Santa Clarita, CA
Thanks for the measurements, did you use the stock coils up front.
jvalente
calgary, ab
2025 4Runner Sport
Its 4wd
AJ Negi,
I noticed you are in calgary as well. I'm looking to add the same to my 2025 Sport. Toying with the idea of doing it myself but if I find a good shop I may hire it out. Could you share where you got yours done?
aj negi
Ajay
Calgary
Hello
I installed from grizzly trucks SE calgary
You can get it installed by any mechanic shop who works suspension system
You can also get it done by yourself if you have proper tools later get the alignment done from shop
jvalente
calgary, ab
2025 4Runner Sport
Hello
Awesome thanks I'll look them up. How do the 5100's ride for you? Would yo usay they are similar to stock. My understanding is that the Sport suspension is on the stiff side so wondering if the 5100's with stock coils would be softer, same or stiffer. How was your experience.
