Cannot shift manually in 4LO
porkyfly
Mid atlantic
2025 4runner TRD Offroad
Setting the gear lever to manual shift mode and upshifting does not do anything in 4LO.
I don't like being stuck at 2.5k rpm in 4lo, too loud and too much engine braking
Anyone else have this issue?
shine
Seattle
It’s not really a manual mode, you’re just telling the computer you don’t want it to upshift past the gear you choose.
It doesn’t prevent it from shifting to or staying at a lower gear.
porkyfly
porkyfly
Mid atlantic
so how am i supposed to hit like 4th gear in 4lo? i dont want to go between 4hi and 4lo everytime i go faster than 10mph
shine
Seattle
No idea…. When do you typically switch into 4LO? Is it for slowing down going downhill, or do you find you need it for the torque going on flat or uphill?
porkyfly
porkyfly
Mid atlantic
mostly for steep hillclimbs/obstacles, but I'd like to be able to drive a bit faster between offroad obstacles
Joestac
You should definitely be switching back to 4HI of you plan on going over 10mph or so. Manual also says if you have the rear diff locked you shouldn't exceed 5mph.
HVLA
Lexus
Wow. Had no idea you couldnt manually shift in 4Lo. Seems odd that a manual trans can manage it, but not this super fancy modern 8 speed.
this super fancy modern 8 speed does NOT need to be manually shifted in any gear.
just let it do it's thing in 4lo you'll get the best performance and precision control out of it
bakutheleo
2025 4Runner i-Force Max
Modern transmissions are designed so they will not destroy themselves, hence shifting when you may not want them to. I also own a skoolie--school bus converted to an RV. It has a big diesel engine and Allison transmission. You can set it manually to, say, first gear if you want--but it will ignore that and shift to a higher gear anyway so it will not damage itself. So, not like the old days.
As said, it is probably usually best to just let it do its thing...it is probably smarter than we are on this in most cases :).
