Papa Smurf
Alberta
4 Runner TRD PRO
Interesting. Did you install the Ravelco yourself or had it professionally installed?
I don't have one but might look into it. Unless you have very good electrical skills i would recommend professional install.
"The Ravelco (pronounced Ruh-vel-co) Anti Theft Device is installed in an easily accessible place beneath or flush mounted in the dashboard of your vehicle. A removable 16 pin male plug (which when not in use connects to your key chain) makes all the electronic connections. A hidden armored steel cable protects the wires from the rear of the RAVELCO base, on through to the engine compartment where all the connections are made and camouflaged. When the plug is removed from the RAVELCO, it is impossible to start the vehicle. There are more than 100,000 different combinations. NO MASTER PLUGS."
Given time anything installed can be uninstalled or bypassed but the time needed would prevent almost any theft of your vehicle. They would be better off towing it away.
The_Dark_Knight_Forever
J.
Houston, TX
I've been thinking about this device or a similar one but I've read people can have electrical issues with them & I also wonder what the usable life of these devices are. I keep my vehicles for much longer than most.
TMLifer
I finally received delivery of the 41.22 kill switch that I had ordered. I ordered the remote / wireless version. It took a while to ship out to me since 41.22 has been informing customers that they have been backed up processing orders.
I'll let you know how my installation goes and how the kill switch works out.
Btw, here's the link to their Web site for the kill switch:
https://41twentytwo.com/product/veh...ipw00hIv2_oapFruAwaJbM4drsjHAVftvICmSWhy9piN3
2025 2026 4runner 6th gen Stolen! Key fob cloning theft method used to steal 2025 4Runner 6th gen 20260408_190055
2025 2026 4runner 6th gen Stolen! Key fob cloning theft method used to steal 2025 4Runner 6th gen 20260408_190137
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Let us know how you end up routing the wire out of the fuse box. I was nervous about it shearing if you just close the lid over it. There is a wire channel that goes out of the fuse box. Still figuring out how that might be used to fish the kill switch wire out.
refone
fel
Miami FL.
4RUNNER HYBRID 4WD TRD OFF-ROAD PREMIUM, Subaru Crosstrek
Guys, check this out. I think for now it's only available in Canada. I still haven't found any more information, like the part number or whether it's possible to install it on our 4Runners. I really hope so. (Intrusion Sensor)
2025 2026 4runner 6th gen Stolen! Key fob cloning theft method used to steal 2025 4Runner 6th gen IMG_0011
J.
Houston, TX
Why did it take until 2026 models for this? 🫤
horbit
DFW
This is neat but a few things to keep in mind.
Its clearly visible the vehicle has it equipped.
Your horns can be cut prior to entry from the front grill.
Sophisticated attacks can create a key from outside the vehicle by accessing CANBUS wires.
Relay attacks will simply trick the car into thinking your key fob is close and the alarm will not sound anyway.
J.
Houston, TX
All that is true but at least this is something & better than nothing. It'll at least deter the lazy & unsophisticated thieves.
I wish Toyota would address the security flaws in all the points you just mentioned though. That would be great.
