drNick
Nick
Ft. Myers, FL
Looks wonderful. Great job!
RAD4RNR
Ray
SO CAL
2025 4Runner ORP Hybrid
Just a weird question. Why would replacing the shocks make a warning light come on in the dash. I've replaced shocks on several vehicle and never heard of this issue?
on the limited and platinum they have AVS, so the shocks can be adjusted for ride comfort/stiffness
personally i hate it on our 23 tundra, doesnt makes a noticeable difference at least for me.
and its not much difference on the 4R either, so imo, its a waste of hardware and money to have it. plus from what i can tell the vehicle rides worse than the lower trims without it.
JMatt
Tucson, Arizona
2026 4runner Platinum
Those wheels look to be poking out more than usual. Are you running wheel spacers? The pro wheels have a +20mm offset and poke a good bit, but those TRD Premium upgrade wheels that you are running have a much narrower offset (+45mm)
These are factory 4Runner TRD Pro wheels with no spacers. The offset is about an inch wider (I think 30mm maybe). So they do have just a little poke.
JMatt
Tucson, Arizona
interesting that just unplugging the shocks doesnt throw any codes.
are you unplugging the shocks at the actual shocks or a fuse ?
Unplugged at the shock. And we have 2,000 miles on them already. No codes, no warning lights, no errors.
DangItsDen
Hayden
Those are not the TRD pro wheels. Those are the TRD Upgrade wheels. They have a +45mm offset. These will not poke outside of the fender unless you're running wheel spacers.
2025 2026 4runner 6th gen Platinum...Pro? Build on King 2.5" shocks raised 3" front / 1" rear + TRD Pro Wheels + 285/70R18 AT4W 536389 (1)
The TRD Pro wheels are these. They have a +20mm offset which is much wider.
2025 2026 4runner 6th gen Platinum...Pro? Build on King 2.5" shocks raised 3" front / 1" rear + TRD Pro Wheels + 285/70R18 AT4W prowheel
2025 2026 4runner 6th gen Platinum...Pro? Build on King 2.5" shocks raised 3" front / 1" rear + TRD Pro Wheels + 285/70R18 AT4W levelkit-4
RAD4RNR
Ray
SO CAL
Ok. I have the ORP so didn't know that was an option.
