How did you clean it ? Hose ? Rags ? ??Cleaned the engine bay, which, after 19,000 miles, really wasn’t too dirty. Yes, I was bored this morning
Used WD-40 contact cleaner to clean the battery, terminals, and the Garmin Power Switch. Then covered that area and the air intake with a waterproof cloth. Sprayed degreaser around the rest of the compartment wherever there was built-up grime, let it sit for a few minutes, then wiped down with a damp rag. Rinsed everything down with pressure washer being careful to keep the sprayer a couple feet away and using a broad, sweeping motion. Used a leaf blower to get excess water out.How did you clean it ? Hose ? Rags ? ??
I live in fear that I’m not going to get it to fit back together right given the amount of plastic clips. All for one small grill. But I still have it on my to do list.![]()
2 hours and 50minutes from hood up to hood down. YouTube time included. Not hard but patience required.
@get.outside.75 Nice, what did you use to cover the empty camera hole in the new grille? Thanks!![]()
https://kocreations.shop/products/heritage-grill-camera-hole-plug@get.outside.75 Nice, what did you use to cover the empty camera hole in the new grille? Thanks!
@get.outside.75 Awesome, thank you! Are you happy with the upper grille glossy and bottom matte? Seems to look fine in the pictures but not sure how it looks in real life.https://kocreations.shop/products/heritage-grill-camera-hole-plug
It's small 3d printed plug. Since I got the glossy TRD Pro grill, I did a light sand and sprayed it with some gloss black paint (it comes matte finish). Couple dabs of superglue on the corners to hold it in. Cheap and easy and looks good![]()
Yep I am very happy. For 99% of people, you would have to point out the difference. It's even less noticeable on the limited because I have a glossy black valence where the fog lights are.@get.outside.75 Awesome, thank you! Are you happy with the upper grille glossy and bottom matte? Seems to look fine in the pictures but not sure how it looks in real life.
Thanks again!
