Any suggestions on how and where I can mount this air compressor?
FlaRunner904
jon
florida
2025 toyota 4runner
Was looking to put it in this little slot right here. But looks like I’d have to build a frame for it or something. What’s the community’s thoughts here. TIA
2025 2026 4runner 6th gen Any suggestions on how and where I can mount this air compressor? IMG_2927
2025 2026 4runner 6th gen Any suggestions on how and where I can mount this air compressor? IMG_2928
2025 2026 4runner 6th gen Any suggestions on how and where I can mount this air compressor? IMG_2929
Joe Dirt
I toyed with that same idea of mounting in the engine, then I just decided to plug into my trailer port using this. This way I don't have to fiddle with opening my engine Hood .
Oh ! I'm not an advocate of any particular brand.
2025 2026 4runner 6th gen Any suggestions on how and where I can mount this air compressor? Screenshot_20251213_141603_Chrom
Bernie
2018 Mercedes AMG GTc
That’s exactly where mine is mounted. The installer used a bracket; not sure if they sourced it from ARB, but it fit perfectly in that space.
vready
Vince
Hood River, OR
Mad Ghost
Wylie Texas
4Runner ORP and Avalon
Have you used this yet? I also looked at this one but was afarid that it might take to long to fill up from 20 psi
Joe Dirt
Yes I have used it as testing in the garage where I deflated to 15 lb then gassed up to 34. I usually run between 34 and 36 for Highway. Very quick took around 3 minutes per tire. Really easy to set up just plug into the hitch power and have your engine running and go for it.
I'm never in a hurry to deflate or inflate like some of these other tools offer. I like this because it's simple and I can share it with friends if they need it.
Just look at the specs and do a little investigation on what the key items are. Overheating PSI pressure per wheel they even show tire sizes as the average inflation rate.
Personally, I want to install the Trailhunter compressor in the same spot the TH has its - there is space there and a power connector - if only I could find the part including the trim pieces (yes I know there are thread on this - I'm watching to see if anyone successfully completes this.)
In the meantime I am very happy with Wolfbox Jumpstarter air compressor which fills my 285/70/18 tires from 24-36 PSI in <3 minutes and fits in the storage area behind the hybrid battery (along with an umbrella, a come-along, some ratchet straps and tools).
But the reason I'm bothering to comment on this thread:
My OTT tuner observed that someone had moved their ECU down and over to make room for a compressor and the compressor and mount had to be removed for access the ECU for the tune. I suspect ECU access could also be an issue for some maintenance. So just a caution for folks installing compressor in that general location to try to keep access to all those convoluted ECU connectors from being hindered. Not saying that the install above that Vready posted does this - it looks like at least the top two large ECU connectors are still accessible - just a comment from an OTT Tech describing a tune that took longer than normal. (Honestly, that ARB and bracket looks really well done.)
fabian
Fabian
Savannah
GR Supra
I attempted to order the Trail Hunter compressor (PT 949 89241) for a 26 TRD Pro and was told that because my Vin# didn't come with it I was not allowed to order it. That makes no sense at all. Why would someone with a Trial Hunter try to order a part that comes on the truck? I'll figure out how to get one, I just won't use my Vin#
I truly hope you are successful in getting the TH compressor into your SportP. But am almost certain that one part number is not everything you need. Suggest reviewing this (and related) threads: Thunter compressor. Please post your experience in that thread.
