Cali Raised LED Premium Roof Rack
rocktheroad
Tampa
4Runner TRD ORP
Hi guys,
Has anyone put this rack on a 2025 model? After a long wait, I finally got mine, but there’s no installation manual. They only sent me links for the Tacoma 2024 and the 5th Gen 4Runner. I found another install video for the 5th Gen, but there are some differences that are a bit frustrating.
1. In the 4Runner videos, the rear rack mounts go on the last crossbar. If I do that, there’s no way to position the front roof rack right.
2. The rear and front rack mounts are different from what’s shown in the videos, so I'm not sure which way is correct.
3. One side of the dual amber/white LED bar just won’t fit on the provided mount. The other side barely works, but it’s tough to screw in and doesn’t line up right. I’m stuck deciding whether to force it or just give up.
4. The front side lights have been moved to a more forward spot.
5. The worst part is that I received 5th and 6th 360-degree lights, although those are from Tacoma 2024. Instead, I was supposed to receive a set of inside LED lights. However, those I got are for the 2019 4Runner.
I am really scared if I got real parts that are for the 2025 4Runner.
After unboxing everything and measuring a ton, I figured out that the rear rack mount should go on the second crossbar from the back, facing the rear (which is different from the 5th Gen 4Runner setup). There's also a different spot where a front rack mount can fit between the crossbars.
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1761532733084-q3
It looks to me like this is the only way to line up the back end with the shark fin and the roof’s edge. The official picture doesn’t even show a back plate, and I can’t figure out how they attached or aligned the back of the roof rack.
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1761533394158-bo
The other pictures are from the 2024 4Runner, and honestly, they’re not any better than the videos I was checking out.
This roof rack is big and solid, but I’d really dislike putting it on the roof only to discover it needs to be put together again. Has anyone set this up and can share some tips?
Thanks!
odins_beer'd
Now that you have lived with the cali raised roof rack for a while, what are your thoughts? I am about to get one and wanted to see what you think of yours.
It’s great, looks fantastic and the deflector for the light bar is a nice touch. My only gripe was the hardware used to connect the rack to the extrusions. There’s 12 connection points and 4 backed out after a hard weekend off-roading.
I replaced those 12 connection points with stainless steel carriage bolts, washers, and lock nuts with anti-seize. Has been perfect since then with virtually no sound. I haven’t really heard wind noise up to 70-75 mph. I would fully recommend as long as you replace the connection hardware. Much easier to tighten/loosen this way as well.
See this reference thread
https://www.tacomaworld.com/threads/improving-the-cali-raised-roof-rack.704714/
ttominator
Waco Texas
Any chance I could get some photos of the rack on the runner? Really want to see what it looks like without a RTT and any additional equipment.
Thanks a ton!
rocktheroad
Tampa
4Runner TRD ORP
New fear unlocked... I'll have to check mine... I didn't go anywhere off-road, but Florida roads could count as off-road on some parts
rocktheroad
Tampa
4Runner TRD ORP
I have led bar and 360 light on mine... :(
ttominator
Waco Texas
That's the set up I am looking at as well. Really want to see what it looks like in the real world if you could put up some pictures. I am also thinking about getting a couple Molle panals for the top as well.
odins_beer'd
Thanks a ton!
The only picture I have is this but they originally sent the wrong front bracket so it doesn't sit fully flush in the front. Hopefully this helps. If not, I'm moving at the end of February and will be able to take my RTT off and can send a picture then.
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1768954228408-ea
rocktheroad
Tampa
4Runner TRD ORP
I keep forgetting to take some pics when it is daylight... here are two that I had on my phone. This is with the front valance in the closed position... Hopefully, I will remember to take better pictures, and the one with the visible led bar.
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1769127321144-3q
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1769127380659-gd
ropdykex11
Rich
Portland, OR
2025 4Runner TRD Off-Road
I have this same rack, nice call on the carriage bolts on the attachment points.
Anyone have any ideas on how to get the front valence to sit a bit lower? I have seen other racks(Prinsu, V4x4, etc) have the front valence sit lower to the roof of the car. Removed some of the trim strip to do so. I think the same thing might work for this rack.
Thoughts?
Pic of what i mean:
CaliRaised:
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1770330075713-y
Prinsu:
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1770330108207-5o
This section is cut:
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1770330279442-xo
odins_beer'd
It sits flush now, they actually sent the wrong pieces. Were really cool about it and gave me an 100 dollar gift card for the trouble and expedited the correct pieces.
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1770330576429-q9
2025 2026 4runner 6th gen Cali Raised LED Premium Roof Rack 1770330593004-yf
rocktheroad
Tampa
4Runner TRD ORP
It seems like you might have the wrong front bracket. Mine is almost touching the roof! @odins_beer had a similar issue and they sent him the correct bracket.
odins_beer'd
How do you like the 360 lightning? is it genuinely useful/bright?
ropdykex11
Rich
Portland, OR
ah! didnt see that! good looking out @odins_beer'd
I also bought/installed before the installation video was available (only posted 8 days ago...) so i wouldn't have known any different without looking at the forums.
what silicon sealant did you guys use for the main bolts to the roof?
