No Bass in JBL Rear Subwoofer & Rear Door Speakers
elecfuyu
6G Platinum
@elecfuyu Keep us posted. I’m very disappointed from the audio from the rear. I’m curious what you find out. Thank you!
Booked an appointment on Jan 29th.
In the mean time, going to test out different audio sources see if anything changes.
Gerardo
Gerardo
PNW
Can you disable blue tooth, plug into USB and choose use as car play?
@Boobajoob OMG, genius! LOL
The key was I had to turn my phone bluetooth off before turning on my 4Runner. Then, connected the USB-C cable to the side of the screen. I could then play audio from my phone through the USB-C cable. Then, I went to the "devices" menu and turned on Apple Car Play and it worked! Thank you!
Now we await @elecfuyu's visit to the dealership to try and figure out why the subwoofer is basically non-existent…
elecfuyu
6G Platinum
A quick update of what I currently find.
When set fader all the way to rear, I don't hear any bass until volume around 45-50.
When fader set to middle:
Spotify (basic, no subscription) - sounds terrible, very flat, with bass only start to be visible around volume 35
Youtube music with Premium - much better than Spotify basic, I can start hearing bass at around volume 24 - 30
Apple music (with stored filed on phone not streaming) - sounds best out of the three at same volume.
Test condition: all three source listened within 10 min and switching directing from each other through wireless apple-carply.
Test music: Eminem - Loose Yourself
Source seems to be very important here.
I'm sure Spotify with Premium will sound similar or equal to Youtube Music premium.
Spotify basic: Audio Quality: Lower quality (128-160kbps)
Spotify Premium: High-Quality Audio: up to 320kbps on desktop/mobile.
Youtube Music Premium: Audio Quality: Up to 256kbps.
Apple Music: Hi-Res Lossless: Up to 24-bit/192 kHz (highest quality)
Keep in mind only Apple music provides lossless, so it will defenitly sound better than Spotify Premium and Youtube Premium.
Also Youtube Premium only sounds "louder" than Spotify, it doesn't nessesary means it is better quality.
Also I look up the Tacoma has subwoofer at the driver side rear seat, and I realize that my coworker had the seats down for his dog, this may have some effect in more direct bass.
I am starting to think this is normal on our vehicle... but will have dealer check and compare to others anyways.
6thGen1419
Peter
New Mexico
AI claims that Toyota has the subwoofer driven by the front channel and not by the rear channel, so setting fader to the rear will turn the subwoofer down, according to AI.
elecfuyu
6G Platinum
I've tried FM radio & Spotify via Bluetooth as that's what I have available to me. Both sources are the same result. It's like only the bass in the rear door speakers and subwoofer have been filtered out even with the infotainment bass setting maxed out. I can't find any other settings that would be causing this issue.
You might want to re-read what I did for testing.
2025 2026 4runner 6th gen No Bass in JBL Rear Subwoofer & Rear Door Speakers 1768500836061-9b
horbit
DFW
AI doesn't know everything, it hallucinates, and constantly passes along false information as truth. I use it as a tool and not a source of truth. Verify the sources it provides.
6thGen1419
Peter
New Mexico
I read it. I’ve confirmed on my ORP: lots of bass from speakers and subwoofer via the front channel. Stuck my head in the cargo area and there’s good subwoofer volume. No subwoofer if I set to max rear channel (zero front channel)
6thGen1419
Peter
New Mexico
I verified on my ORP that AI is correct on this.
Chipmink
Mel
Dallas, TX
2025 4Runner TRD PRO
Just a heads up that Spotify does have lossless 24bit/44.1kHz
It is wild how the speakers feel like two different systems at 30 to 45
2025 2026 4runner 6th gen No Bass in JBL Rear Subwoofer & Rear Door Speakers Screenshot_20260124_101149_Spotify
ToyoTech808
Honolulu
25 4runner
The rear subwoofer being soft is how it is designed. Confirmed with another vehicle with JBL system. The rear speakers are also filtered meaning the lower frequencies is cut through the JBL amp. The way that I was able to overcome this is by one stuffing the enclose with polyfill and 2 adding a dsp. I will be doing a write up on my audio adventure. As I have tried different steps to try to get the sound system decent. I feel now I got it pretty decent.
Gerardo
Gerardo
PNW
@ToyoTech Looking forward to the write up. Thank you!
