Glove box latches to cure rattle (3D print)
bkw777
Brian
NJ
25 SR5, 96 SR5
I got annoyed looking for the little grommets to tighten up the glove box door rattle, because even the ones that clearly say they fit the 2025 4runner have a mix of reviews that say they don't actually fit, not even close, so presumably either they fit older 4runners, or maybe Tacoma is different than 4runner etc.
The task is so simple I just made my own.
There are a few other free 3d print models on different sites but they are just STLs with no source cad file and still no clear certainty which models they actually fit. IE, I found one that claims to fit 2024, andother that claims to fit 2025 Tacoma, not 4Runner. Maybe the Tacoma one fits but a few reviews of other ones say not.
So this is a parametric custimizable cad file that has simple numbers for the key dimensions right in it.
You can tell if it will fit before having to find out the hard way by buying and shipping, because you can just see the numbers and see if the holes in your glove box are 13mm x 13mm then it'll fit. Not just because I said "fits 2025 4runner", but because the cad file says 13x13 and you can just go look at your holes and see if they are 13x13. Maybe the hybrid or some other trim level is different than my SR5, maybe 2026 is different than 2025, maybe the lexus or landcruiser is different etc. I don't know and you don't need me to. You can just measure your holes and plug that in and spit out a grommet that exactly fits your holes whatever they are.
https://github.com/bkw777/Grommet_Generator
If you don't have a printer, there are countless 3d print services. You still end up paying and waiting, but at least now you have full knowledge and control over what you're getting instead of the useless descriptions on amazon etc that don't simply give the exact dimensions which would have removed all doubt.
UPDATE: Alternatively, see Vincenzo's completely slick idea of just beefing up the the existing plunger-bumpers:
https://www.4runner6g.com/forum/thr...-cure-rattle-3d-print.8547/page-2#post-109663
Maximus4R
Adam
Nashville
Only this time it's open source with a parametric custimizable cad file that has simple numbers for the key dimensions right in it. You can tell if it will fit because you can just see the numbers and see if the holes in your glove box are 13mm x 13mm then it'll fit. Further, if your glove box has something else, you can just change those numbers and spit out a grommet that exactly fits yours without having to pay someone $12 and wait for shipping just to roll the dice and see if you get lucky.
If you don't have a printer, there are countless 3d print services. You still end up paying and waiting, but at least you have full knowledge and control over what you're getting instead of the useless descriptions on amazon etc.
Thanks for sharing this!
Vincenzo
Southeast
Mine has considerable play but does not rattle. Have you tried the felt or rubber used on cabinet doors? They are self adhesive and available at Lowes or Home Depot
horbit
DFW
Thanks for designing this and contributing to the community. I will see how well it works in TPU, however the glove box has not rattled for me while driving. It does have quite the amount of play.
bkw777
Brian
NJ
25 SR5, 96 SR5
Mine doesn't always make noise, just when the road is rough.
I'm sure felt pads do work great but I didn't try bumpers or felt or anything else because I don't want just any old possible solution, I want a specific solution.
I didn't want bumpers, I wanted grommets.
I didn't want anything that relies on adhesive or glue.
I wanted the door held at the closed end of the travel rather than the open end of the travel.
Now that I have the shape dialed in, I'll get a set commercially printed in black nylon MJF or SLS so they look nicer than my grey pla FDM prototype.
bkw777
Brian
NJ
25 SR5, 96 SR5
For the record, I printed in pla+ and will probably get a set done in black nylon MJF now. Both hard materials that should never wear out from the bolt striking and grinding on them.
The grommets don't work by cushioning, they work by just pressing the door into the spring loaded plunger bumpers in the dash.
Though I'm curious about the possibility of tpu also. Maybe the hard grommets would still rattle if the vibration was extreme, and maybe rubber ones would still not no matter what?
But I've never even tried to push tpu through the bowden setup on my dinky little monoprice select mini 2.
horbit
DFW
But I've never even tried to push tpu through the bowden setup on my dinly little monoprice select mini 2.
TPU doesn't feed well without direct drive extruders.
horbit
DFW
The TPU print kept unseating so I will use PETG which is the strongest filament I have. This did remove the jiggle from the glove box so thank you.
BadTrainDriver
Powell, OH
If you get two sets printed, and they work well, I'll buy a set and pay for the shipping. PM me if you'd be willing to do something like this. TIA!
bkw777
Brian
NJ
25 SR5, 96 SR5
I added a link in the readme. If you select the cheap shipping then it's only like $11 but over a week wait.
The ones I printed myself work well but the MJF ones could possibly come out either tight or loose just because it's a different printer and a different printing process. It's probably fine but you might want to wait until I get mine to be sure.
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Mine seldom rattles, but annoying when it does. Sounds like the truck is falling apart.
Stronger springs behind those two bumpers would prevent the rattle.
For now, I added a small piece of black high-density foam at the top of the opening, attached with 3M two-sided tape. Now the door has a nice firm feel when closing.
2025 2026 4runner 6th gen Glove box latches to cure rattle (3D print) 20260124_115903
Seems like my first post was deleted by the forum nazi’s.
my point was, this is an overly complicated solution. Each to there own, go play on your 3D printer, buy designs, ect.
I used quality silicon bumpers, no play, not that noticeable, etc.
Cost $0.50.
Time to fit 1 minute.
1Volfan
Chuck
Cincinnati
Mine didn’t rattle but I didn’t like all the play in the glovebox door. I don’t have a 3D printer so I ordered the $20 fix from 4Runner Lifestyle and it worked like a champ.​
Jade4rTx
Bob
I used these from 4Runner Lifestyle, have worked great, no more rattle
2025 2026 4runner 6th gen Glove box latches to cure rattle (3D print) IMG_2990
