Glove box latches to cure rattle (3D print)
bkw777
Brian
NJ
25 SR5, 96 SR5
That print looks really good. What printer do you have?
Vincenzo
Southeast
This is how I corrected it. The two spring loaded plungers on each side got upgraded to a stiffer spring. I tried stretching them first, but, made no difference. They actually went back to their original length. I then added the rubber bumpers. No more plastic on plastic violence when you close it. It worked out fantastic.
2025 2026 4runner 6th gen Glove box latches to cure rattle (3D print) IMG_8789
2025 2026 4runner 6th gen Glove box latches to cure rattle (3D print) IMG_8787
2025 2026 4runner 6th gen Glove box latches to cure rattle (3D print) IMG_8790
2025 2026 4runner 6th gen Glove box latches to cure rattle (3D print) IMG_8796
2025 2026 4runner 6th gen Glove box latches to cure rattle (3D print) IMG_8794
Gagi
Gavi
Valley Glen, CA
2026 Toyota 4Runner Trailhunter
Ender 3. I printed with ABS highest quality
And used the first design provided by the member. The fancy one was breaking.
2025 2026 4runner 6th gen Glove box latches to cure rattle (3D print) IMG_3912
bkw777
Brian
NJ
25 SR5, 96 SR5
Well I mean I did write right in the readme:
"This version is probably not good to print at home on a normal FDM printer because the tabs will likely break off.
So this is really only for getting commercially printed using SLS or MJF."
The default version is designed for FDM.
bkw777
Brian
NJ
25 SR5, 96 SR5
This is great. Thanks for the recipe.
Van Solo
Van
Calgary / Canada
What parts and from where please your solution is my preferred style.
Gagi
Gavi
Valley Glen, CA
Yeah no blame’s only big thanks.
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
4Runner Lifestyle product sold out at the moment.
