templarpsi
Robbie
Tucson
2025 Toyota 4Runner Off-Road Premium
Hi Yall!
Installed the OEM cargo lights on my 2025 ORP today and I seriously can’t believe how much brighter the back area is now. The stock setup is basically useless in the dark, but these new lights light up the entire cargo space like a spotlight. Total night-and-day difference.
The install wasn’t too bad, just a little tedious. You do use a Phillips for the cargo fastener, but I didn’t have the right size, so I ended up using a flathead and it worked fine. After that, the main thing is just being careful with the D-pillar trim. You need to pull it toward you, not down. A pry tool helped a lot to pop the clips loose without cracking anything.
Once that fastener is out, you can actually pull the trim back enough to fit the new panel and wiring where it needs to go. Re-aligning everything afterward takes a little patience, but once it all snaps back in, it’s solid.
Overall, the extra light is absolutely worth the effort. The rear cargo area finally looks like it should’ve from the factory. If you use your cargo space at night, this upgrade is a must.
Link for instructions on install:
Link for Install
Link for OEM Part (My dealership I bought from, prices vary per location):
Link for OEM Part
2025 2026 4runner 6th gen OEM Cargo Area Pillar Light Install 6th Gen ORP - DIY instructions & photos 1768274742632-dy
2025 2026 4runner 6th gen OEM Cargo Area Pillar Light Install 6th Gen ORP - DIY instructions & photos 1768274871244-d8
2025 2026 4runner 6th gen OEM Cargo Area Pillar Light Install 6th Gen ORP - DIY instructions & photos 1768274990431-t7
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
Thank you! I’ve been waiting for this post. I’m assuming there is a wiring harness pre installed?
yes
in the pictures
the yellow circles denote the factory connectors
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
To remove the cargo net hooks, twist 90 degrees, then they pull out. Instructions omitted this step.
Then I removed the fasteners with a 10mm socket, per instructions.
Be gentle removing & installing the panels. There are common chassis ground points with many loose wires attached that are easy to get caught up on.
T_Pomp
Anthony
Illinois
Just ordered a set. This is the cheapest I could find them-including shipping.
js_panda_rnr
Thanks for reminding me. Been meaning to pick this up. $209 shipped to SoCal from your Tucson dealer!
Phil99
Phil
Overland Park, KS
2025 4Runner Off Road Premium
Just installed mine. Took about 45 minutes with your post's guidance and the Toyota instructions. Thank you!
($211 from Tulsa, OK dealer)
talmadge
Timothy
SLC, UT
Thanks for the write up OP, it’s a bitch to spend $200 on some plastic and LEDs that the vehicle should’ve come with anyways, but wow they make a huge difference. Also, I found where the air compressor was hiding in the process.
2025 2026 4runner 6th gen OEM Cargo Area Pillar Light Install 6th Gen ORP - DIY instructions & photos IMG_2374
2025 2026 4runner 6th gen OEM Cargo Area Pillar Light Install 6th Gen ORP - DIY instructions & photos IMG_2372
C/G
Cary
Orange County, CA
Great info. Thanks for the pictures and docs, very helpful.
C/G
jw4runner
JONATHAN
Boulder co
Toyota 4runner
I just had these installed by the dealer, I negotiated them into the purchase. Based on the appointment it took them about 20 minutes to complete and looks completely different at night!
JCP
James
Bay Area
2026 4runner TRD Offroad Premium
Can they be turned off by using the dome light control?
MTRunner
Michal
Tustin
2026 Platinum
Amazing install write-up! I clicked your link for the part and it took me to the Toyota website. I got irritated realizing that....because I agree, why the hell wasn't this stock on the car? For a vehicle that we spend so much time in being in the cargo area, this should've been standard.😂
RunnerRocks
RedDog
Nature
With our 2026 ORP Non-hybrid...
No. With the dome light switch to OFF, both cargo area lights remain ON.
