climbv1
Guanqun
4runner trd pro
For anyone wondering if a 285/70R18 KO3 (E-Load, ~33.6") fits in the factory under-bed spare location: The good news is: Yes, it fits without modifications, but it is really tight... No need to modify the bracket or anything, but you have to intentionally push the tire back toward the hitch while cranking the chain to leave about 1/5" of distance to the panhard rod.
Concerns: That 1/5" distance is close enough to risk rubbing when the panhard rod moves during off-roading. Also, because the spare tire hangs significantly lower than stock (due to increased width), it will completely ruin your departure angle and will likely strike rocks on technical trails.
I will go with this as a temp solution but eventually I think I will have to install a tire carrier.
2025 2026 4runner 6th gen KO3 E load 285/70R18 Spare Tire Fit Test IMG_0212
2025 2026 4runner 6th gen KO3 E load 285/70R18 Spare Tire Fit Test IMG_0223
sliver
Guy
Atlanta GA
Perfect! I was going to go with that size, but was afraid that might be a problem, since I have an on board compressor, I was thinking of partially deflating it to help, I might not even to go that route, that's great!
Moby
Moby
NJ
TRD OR Premium
Thanks for sharing. It’s helpful
jcash25
jason
Houston
2025 TRDO Premium
Damn... is it the angle in rear is looooow. i know KO3s are heavy but damn
IRFAN0922
irfan
2026 Toyota 4Runner SR5
My experience with BFGoodrich has been bad. In my opinion, these are some of the most popular tires with some of the poorest on-road performance. After about 15,000 miles, they also become noticeably louder.
jcash25
jason
Houston
2025 TRDO Premium
your suppose to rotate your tires....
climbv1
climbv1
Guanqun
4runner trd pro
yea, this might be ok for some mild overlanding, but definitely not ok for rock crawling.
climbv1
climbv1
Guanqun
4runner trd pro
I really like the KO3s. They're very capable off-road, grippy and strong. As for noise, I honestly can't tell much difference from my stock Toyo Open Country ATIIIs. And the white letters look great on the 4runner.
jcash25
jason
Houston
2025 TRDO Premium
I was going to say i dont know why they added a layer of white rubber on the new tires... i havent had a new set kO3s but i love my old tires...I had them on a 3/4 4x4 dodge diesel so noise wasnt even thought of. Id NEVER put them on a 4runner way too heavy rigid for a light 4runner.
Unless you need that 10ply bc you shred the sidewalls on rock.
I also saw this and i probably wont be getting BFGs anytime soon...
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Are you sure that spare is fully seated ?
Here's my Toyo OC AT3 LT275 /70 R18 125S E1 spare.
2025 2026 4runner 6th gen KO3 E load 285/70R18 Spare Tire Fit Test Toyo1
2025 2026 4runner 6th gen KO3 E load 285/70R18 Spare Tire Fit Test Toyo2
climbv1
climbv1
Guanqun
4runner trd pro
It was fully seated. I think it's just my tire is slightly bigger.
climbv1
climbv1
Guanqun
4runner trd pro
your money your choice. :)
jcash25
jason
Houston
2025 TRDO Premium
no doubt.. ! was just showing what will happen when you scrape that sidewall, you will be running with a white stripe on your sidewall.
