Interior Fuse Box - Hardwiring Dashcam question
MStarmer
Michael
WA
2026 4Runner TRD ORP
I think I found an acceptable solution. I ended up removing all the support ribs on the portion that covers the fuse box. After that I think there is tiny gap between the fuse taps and the cover, initially I thought I'd end up just routing a hole in the panel, but I think I can live with this.
2025 2026 4runner 6th gen Interior Fuse Box - Hardwiring Dashcam question Bottom Panel
2025 2026 4runner 6th gen Interior Fuse Box - Hardwiring Dashcam question IMG_0001
kburrito
2025 TRD Off Road Hybrid
What tool did you use to cut this?
MStarmer
Michael
WA
Just a flat chisel blade X-Acto knife. I was going to clean it up a little but it's functional and I can't see ever really needing to take it off again unless I gotta replace a fuse. Way better than cutting a hole it.
horbit
DFW
I tapped into the blank bottom right fuse for 12v ignition. Had to do the same cutting to make sure the kick panel was not knocking the tap out. This was for a BantamX IGN input but this thread was helpful. Thank you!
2025 2026 4runner 6th gen Interior Fuse Box - Hardwiring Dashcam question 1785340600232-y4
MStarmer
Michael
WA
This just reminded me to clean up the bottom of the panel. Looks a little better with a quick sand.
2025 2026 4runner 6th gen Interior Fuse Box - Hardwiring Dashcam question IMG_7408
