iForce max (hybrid) vs iForce (non hybrid), pros and cons listed
kekecarioca
_CAC_
Pros and cons of each setup, let me know what I missed
iForce pros (non hybrid):
  1. lighter vehicle -375lbs
  2. slightly faster acceleration
  3. more cargo capacity +7.6cu/ft
  4. less complex
  5. cheaper starting msrp
  6. no hybrid components, easier access to the engine components
  7. better highway MPG
  8. No need to swap the NiMH battery when it dies
iForce cons (non hybrid):
  1. more stress on the newly designed turbo engine
  2. potentially less durable since there's more stress on the turbo
  3. more emissions
  4. less power
  5. lower power AC outlet 400w
  6. less torque for 4Lo off-roading
iForce max pros (hybrid):
  1. less emissions
  2. more power
  3. less stress on the turbo
  4. better city MPG
  5. higher power AC outlet 2400w
  6. more torque for 4Lo off-roading
iForce max cons (hybrid):
  1. less cargo capacity -7.6cu/ft
  2. slightly slower acceleration
  3. more complex
  4. heavier vehicle +375lbs
  5. more expensive msrp
  6. harder to access engine components for maintenance
  7. worse highway mpg
  8. NiMH battery will need to be swapped when it dies
(towing capacity for the TRD off road MAX and regular is actually the same, both rated at 6000lbs)
Another few Hybrid pros (characteristics):
-regen braking ( longer brake pad life)
-you can feel the extra torque on daily driving.
-It goes on EV mode more often than I thought it would. You can coast down from an avenue into a neighborhood and curse for a while in EV only. it seems to do it more often if battery is over half full.
-A/C runs for a good while with engine off.
negated by using radar cruise control in town or busy highways. the new gen tundra people have been going thru brake pads in as quickly as 20k miles using radar cruise control since it is applying the brakes to maintain distance to vehicle in front.
thats why they added a warning light to the MID screen to show when the brakes are applied in radar cruise control. but thats not the only reason for the warning light.
kekecarioca
_CAC_
I heard of that one on another post, that the rear brakes go sooner... Also someone else called BS on that. Let's see how these 4runners do on that aspect. If true, it won't affect me much since I tend to use radar cruise on back country roads or empty sections of highway.
kekecarioca
_CAC_
On the subject of engine setups :
I' ve been driving a Trailhunter for 3 weeks now. I drove around a non hybrid 4runner TRDORP yesterday (again) and my statement is :
- non hybrid is quite good on take off acceleration and throttle response. Plenty capable and acceptable for today's standards and impressive 4banger.
- Hybrid is next level in response and power delivery. YOU FEEL the torque on daily driving instantly : Passing is an ultra confident effort in tight situations.
LARIN
Stitch@317
2025 Toyota 4runner SR5
Took my 2021 vehicle in at 50k no radar cruise and only needed rear brakes, I asked the tech that does not seem right, then asked around to other places to make sure I was not getting ripped off, this is what I found, because rear disc brakes plus abs and stability control, rear brake bias is used allot more.
kekecarioca
_CAC_
Now that you say that, we had to replace rear brakes on our 19' Forester @ 60k and currently @ 115k or so and front brakes are still "good".
TrdProGirl84
2025 Toyota 4Runner TRD Pro
I knew when I bought a SUV I’d be getting a TRD Pro. And it just so happened it’s a Hybrid model. So that’s why for me…
