Fox 2.0 vs 2.5 to improve ride quality?
Fox 2.0 vs 2.5 for ride quality
  • Total voters
xTeamAmerica
Ryan
Maine
6th Gen TRD Off Road Premium HV Underground
Thinking about upgrading my suspension to Fox 2.0 or Fox 2.5. Fox 2.0 is roughly around $1700 and 2.5 is around $2300. I live in Maine so we get harsh winters which means rough roads, pot holes and so on. I wouldn’t be “off-roading” I’m just looking to improve my overall ride quality but also know it’s not all flat perfect pavement. I wouldn’t mind spending the extra $500 on the 2.5’s if it’s worth the upgrade I just want to make sure it’s not overkill and tailored more towards off-roading. Thanks for the advice! (TRD Off Road Premium)
porkyfly
Mid atlantic
2025 4runner TRD Offroad
Just get the 2.0s
I got 2.5 rear and 2.0 front, looking back 2.0 all around would have been enough. Just remember to lower the front shocks before putting them on
zcmack
las vegas
I recall there being some discussion about the 2.0s having some sort of difference that reduced noise, vibration, harshness compared to the 2.5s. search the forum, its probably in the thread where all the other off road premium folks realized we got hosed. 😆
this is incorrect, i was thinking of this post: https://www.4runner6g.com/forum/thr...-improve-ride-quality-trd-orp.4525/post-88528
where the poster mentions the 2.5 elites having spherical bearings instead of poly bushings.
porkyfly
Mid atlantic
from Fox themselves:
The Performance Series 2.0 and 2.5 coil overs and shocks will provide equal compliance and ride comfort for daily driving demands. The larger diameter damping piston and greater oil volume of the 2.5 will provide improved control for more demanding off road conditions.
Both options are preset for an approximate 2.0” ride height increase over stock. Your actual ride height increase may vary due to TRD Off Road trim.
The Performance Series 2.0 is our best selling option by virtue of best ride improvement per dollar.
zcmack
las vegas
edited my mistaken post above. i vote you go for the 2.5s because you won't have to wonder "what if?" buy once cry once.
ShotsFired
Gary
Fairview, pa.
2025 Toyota 4Rummer TDR
I live in Pennsylvania. I kind of off road every day in the pothole raised pavement capitol of the United States. Not to mention the tar they use to fill cracks in the asphalt. Rt 5 along lake Erie shoreline feels like a rumble strip. Do you think 2.5s would help?
xp0nex
2025 4Runner ORP
You should really think about your use case. If you are looking for better daily driving comfort you should be looking elsewhere as those are designed for baja style off roading.
I don't know about Fox but I've done Kings before and they were actually stiff, like a lot stiffer.
xTeamAmerica
Ryan
Maine
Just received this from Fox, so I guess they are saying the 2.5’s would be worth the money and not overkill
Just received this from Fox which makes it sound like the 2.5’s would be worth the upgrade and not overkill for daily driving which is kinda opposite of your post lol
2025 2026 4runner 6th gen Fox 2.0 vs 2.5 to improve ride quality? IMG_5024
porkyfly
Mid atlantic
I truly dont think it matters. I upgraded to 2.5 rear first, and realized that only @alldogsoffroad adjusts front coilovers before shipping them to you, and they only sell the 2.0. That's the only reason I have 2.0 front 2.5 rear. Even my asymmetrical setup works perfectly fine and the ride quality is far better than stock.
Of course Fox will want to upsale you lol its their product. For daily driving, the 2.5 will probably have less head toss (i have none) but be slightly firmer
spyder40
Indiana
2021 4Runner ORP
Had Accutune build my 2.5's on my 5th gen with DSC's so I could control the compression damping depending on my load and driving needs. Could firm up the low speed so no body roll in corners but set high speed soft for cracks and bumps. Firm up the rear when pulling my trailer. Really liked them. Accutune now has their own brand which are a little cheaper but comparable to the Fox or Kings. Haven't done anything on my 6th gen ORP...yet. Bilsteins work but are stiff and missing my Fox
porkyfly
Mid atlantic
Another data point: one of the 2.5 rears I had unfortunately blew a seal and all the shock fluid leaked out. I was doing an easy trail (3/10 OnX) at high speed pretending to be a baja truck. I don't think I pushed it that hard, although that is subjective (my inexperienced passenger was shaking when finally let out).
I don't really know why the shock failed, perhaps it's because I'm running them with all-stock components and stock height so they have less travel to work with? Not really sure because they are advertised to work with 0-2" of lift. Will be sending the failed shock back to Fox for RMA, hopefully they can analyze cause of failure.
Anyways I had a set of 2.0 rears installed to match my front, because I'm worried the 2.5's might fail again. Sounds counterintuitive but since the 2.0's are rated for less lift they might match the stock height profile and bumpstops better. Ride quality is very similar between the 2, the 2.5's might have felt a tad softer with slightly less head toss actually.
2025 2026 4runner 6th gen Fox 2.0 vs 2.5 to improve ride quality? IMG_5371
2025 2026 4runner 6th gen Fox 2.0 vs 2.5 to improve ride quality? IMG_5513
xp0nex
2025 4Runner ORP
Sounds to me like a build issue with the shock.
spyder40
Indiana
2021 4Runner ORP
Loved my Accutune Fox 2.5's on my 2021. Crazy one blew on you. Were yours resevoir with DSC's? Liked being able to adjust for what I was doing
Macaque
Washington
2026 TRD OR Hybrid
Ask Fox why it failed. Looks like the end cap is coming out rather than failing at the shaft seal which is interesting. I don’t know about Fox internals yet to make an educated guess. Could be a build issue, heat increasing the pressure in the shock and popping that out, or even topping out too hard.
Dr_Al
Alex
Rav4, Tundra
I would think the end cap coming out like that would be a sign that they were extended too far and the piston hit the cap. I doubt that's possible with stock IFS. Even with a 2" lift I would like to think the travel length of the shock would still be longer than the suspension travel. Most likely just a bad machining of the threads.
I would like to think that the 2.5s are designed to handle harsher terrain. We have lots of potholes around here but most people don't drive through them like they are running the Baja 1000. I assume they have more fluid in them to resist heating up quickly. Also they will handle heavier tires better. I don't think you'll see enough of a difference to justify the added expense. However if you want the 2.5s then I would get them. It's far cheaper to get exactly what you want now than upgrade down the road.
