Dash Cam - Rear Camera Mount
DirkC
Dirk
Atlanta, GA
RAM 1500
On a 4 Runner, how are folks attaching the rear facing camera since you can't mount on the window as it rolls down?
Donmega87
Ryan
AB
2026 Toyota 4 runner Limited
Good question. I put mine on the window out of habit and it lasted all of 3 days!
Forgot about it then rolled it down while the dog was in the back lol
shine
Seattle
3D printed mount on headliner's clip:
https://www.thingiverse.com/thing:4963162
If you don't have a 3D printer, get it on Amazon for $13: https://amzn.to/45Cq8bz
Then mount like I did below. Run wire hidden in the headliner to the front.
2025 2026 4runner 6th gen Dash Cam - Rear Camera Mount 20260118_172850
2025 2026 4runner 6th gen Dash Cam - Rear Camera Mount 20260118_172125
2025 2026 4runner 6th gen Dash Cam - Rear Camera Mount 20260118_172835
Protip: mount on the passenger's side clip, NOT center. This will allows the camera to see the rear when the window is dirty, like this:
2025 2026 4runner 6th gen Dash Cam - Rear Camera Mount images_137a6628-928c-4b
dante116
Sacramento, CA
2026 4Runner Off-Road Premium
2025 2026 4runner 6th gen Dash Cam - Rear Camera Mount {filename}
This is exactly what I did for my 2026 4Runner. Used the existing mounting clip and that 3D printed piece from Amazon. Works well, holds it solidly, and I don't have to worry about outside moisture or having it stick to a moving rear window. :)
depending on the model you go with, some attached to one of the rear headliner clips, others use 3m doublesided tape
you can do a simple goo search for 4runner rear dashcam mount
ifunlisted
AZ
look awesome! Please share the file if you don't mind 🙏🙏
Here you go! And some tips for 3D printing...
#1 make sure the person knows what they're doing and they're familiar printing with ASA (if that's the material you choose)
-I did a few in ASA and ASA-CF, both materials worked very well but the CF version had a higher-quality look... don't use standard PLA or anything that can't handle heat or UV
-Use 0.1mm-0.15mm layers
-Use at least 40% infill (gyroid works great)
-Use at least 4 internal walls
-Best results for my prototypes were when the mount was printed on its side
Fyi, if you pull the headliner button clip out too many times, the little 'Christmas tree' ribs will start to break down and it'll lose grip. The oem replacements are part number 90467-05164 (then pick the right color). If you use black, these work great too https://www.ebay.com/itm/235706541254.
If you pull the headliner button clip out too many times it'll start to lose it's grip. The oem replacements are 90467-05164 (then pick the right color). If you use black, these work great too https://www.ebay.com/itm/235706541254.
Much appreciated it man 🙏🙏
