Not made in China
Bicycle
Hey 4r 6gen owners are you aware of a published break in procedure for the new 6th gen (non-hybrid)? Thanks.
Updated with answer from below by @Jack:
Per 2025 4Runner Owner's Manual:
Breaking in your new Toyota
To extend the life of the vehicle, observing the following precautions is recommended:
● For first 200 miles (300 km):
- Avoid sudden stops.​
● For first 500 miles (800 km):
- Do not tow a trailer.​
● For the first 1000 miles (1600 km):
- Do not drive at extremely high speeds.​
- Avoid sudden acceleration.​
- Do not drive continuously in low gears.​
- Do not drive at a constant speed for extended period​
Jack
Jack
SLC, UT
FJ
Breaking in procedure is listed in the Owner's Manual:
Link to Owner's Manual & Warranty Maintenance Guide: 2025 4Runner 6th Gen ?
Parker516
Parker
Old Westbury - NY
Incoming TRD OR
Recommended "soft" break-in vs. a "hard" break-in
I may be opening up can of worms with this ? but anyone not believe in following recommended break-in period procedure, but instead prefer a hard break-in where you drive the engine hard from day 1?
Hard break-in theory being that it'll result in allow piston rings to seat better against cylinder walls, which results in better power, compressions, fuel efficiency and engine life...
FWTBT
Northeast
5th Gen 4Runner
There’s a middle road approach, which is what I always do on new cars: follow the recommendations BUT make sure to induce engine braking to help seat the rings. Vary the RPMs a lot, rev it up (within the recommended guidelines) and let it coast back down. Also downshift from time to time.
Idea is to create back pressure to seat the rings. That’s what the “drive it hard” theory is about. And it can be done within the guidelines.
Michigan
2021 Jeep Wrangler Willy's
I'm purchasing out of state and it'll be roughly a 6 HR drive back home. Should I be concerned about the following point?
-Do not drive at a constant speed for extended period
kekecarioca
_CAC_
That's what I have heard as well from Long time experiences... That approach might be harder to do (engine breaking) in the I-Force max due to it switching to EV on coasting down, not sure there.
kekecarioca
_CAC_
That's an up to you deal. The engine will not fail because of that, but if you want to sleep better at night, try taking extra time on your way back and get on and off the Freeway often and take a few back roads or service roads if possible. Basically practice what @FWTBT said above by keeping the engine working it's way up and down the Rev range (within manual rec.). -that's just my 2cents on the matter-
Congratulations in advance on your new 4?‍♂!
LLL1990
United States
Toyota Camry and Ford F-150
You won't get engine failure from not following the break in procedure but years and many miles from now you might have an issue with oil burning. The best break in procedure is lots of city driving. The engine is constantly going up and down in revs and the transmission is doing a lot of shifting.
LLL1990
United States
On the drive home plan part of your route on back roads that go through small towns. Your 6 hour drive may turn into 10 hours but you may enjoy the slower pace in your new ride.
Kokorone
Gabriel
Laguna Hills, California
2025 4Runner SR5 4WD
To our existing owners @Kokorone @jerrycaparros @nbradley -- are you following recommended break-in period procedures exactly? Halfway? or Full Send? ?
Hmm. I've punched it twice now but maybe I'll stick to these recommendations just to be a little nicer on the engine and powertrain haha
mars001
2003 4Runner SR5 4.7 V8
If anyone thinks that they are better than Toyota engineers, go for it! ?
YotaOverland
Mack
You just want varied load on the engine to seat piston rings more effectively, you can do this a bit by speeding up and slowing down occassionally. Pull over and take a lot of breaks which will help naturally.
