- First Name
- Jay
- Joined
- Dec 16, 2025
- Threads
- 1
- Messages
- 11
- Reaction score
- 18
- Location
- Washington
- Vehicle(s)
- 2025 Toyota 4runner Off-Road, 09 Legacy Spec.B, 2019 Subaru Crosstrek
- Thread starter
- #1
Installed Limited Headlights w/ 4Runner Badge (Etsy
) on the Hood
For anyone interested in doing this upgrade, itās fairly simple. I highly recommend disconnecting the battery anytime youāre working with electrical components such as headlights or fog lights.
Part Number: 81070-35661 - Unit Assembly, Headlamp, B Left Hand
Part Number: 81140-35661 - Unit Assembly, Headlamp, B Right Hand
When removing the headlights, make sure to disconnect the two harnesses located on right passenger side of the headlight. (Be sure to connect them properly once you're finish, otherwise you'll unlock a can of worms; check engine lights, codes, etc. etc.)
Please refer to video: How to remove front bumper
The entire process takes roughly 1.5 hours from start to finish.
It is purely Plug and Play, no additional harness required for the installation.
Limited(Premium) headlights have three connectors total:
The headlights can be adjusted by using the headlight leveling control knob on the driverās side.
Overall, a straightforward install and a great OEM+ style upgrade.
- One connector for the DRL/turn signal
- Two connectors for the low beam and high beam
- One extra connector that is not used (I pointed this out with an arrow in the photo of the back of the headlight)
