J4runner721
Jay
Washington
2025 Toyota 4runner Off-Road, 09 Legacy Spec.B, 2019 Subaru Crosstrek
Installed Limited Headlights w/ 4Runner Badge (Etsy šŸ˜…) on the Hood
For anyone interested in doing this upgrade, it’s fairly simple. I highly recommend disconnecting the battery anytime you’re working with electrical components such as headlights or fog lights.
Part Number: 81070-35661 - Unit Assembly, Headlamp, B Left Hand
Part Number: 81140-35661 - Unit Assembly, Headlamp, B Right Hand
When removing the headlights, make sure to disconnect the two harnesses located on right passenger side of the headlight. (Be sure to connect them properly once you're finish, otherwise you'll unlock a can of worms; check engine lights, codes, etc. etc.)
Please refer to video: How to remove front bumper
The entire process takes roughly 1.5 hours from start to finish.
It is purely Plug and Play, no additional harness required for the installation.
Limited(Premium) headlights have three connectors total:
  • One connector for the DRL/turn signal
  • Two connectors for the low beam and high beam
  • One extra connector that is not used (I pointed this out with an arrow in the photo of the back of the headlight)
The headlights can be adjusted by using the headlight leveling control knob on the driver’s side.
Overall, a straightforward install and a great OEM+ style upgrade.
2025 2026 4runner 6th gen Installed Limited (Premium) Headlights on 4Runner TRD Off-Road -- part numbers & tips 20251229_111059
2025 2026 4runner 6th gen Installed Limited (Premium) Headlights on 4Runner TRD Off-Road -- part numbers & tips 20251230_093534
2025 2026 4runner 6th gen Installed Limited (Premium) Headlights on 4Runner TRD Off-Road -- part numbers & tips 20251228_134729
2025 2026 4runner 6th gen Installed Limited (Premium) Headlights on 4Runner TRD Off-Road -- part numbers & tips 20251229_151620
2025 2026 4runner 6th gen Installed Limited (Premium) Headlights on 4Runner TRD Off-Road -- part numbers & tips 20251228_134744
2025 2026 4runner 6th gen Installed Limited (Premium) Headlights on 4Runner TRD Off-Road -- part numbers & tips 20251229_151632
Maximus4R
Adam
Nashville
Ugh. I need to quit finding stuff I need in this forum. Did you order straight from Toyota? I keep holding out hope that Form will release lights that I love, not sure what is taking them so long.
J4runner721
J4runner721
Jay
Washington
They were on sales at Toyota of Santa Margarita for 30%, will probably go away after Holiday lol. Trailhunter and TRD PRO are back orders, since alot of people are buying those.
Looks great! And they perform well too. I live in heavily wooded boonies where there are no street lights etc. so I am very critical of headlight performance. The OEM premium lights are excellent.
When you do this upgrade, does the headlight leveling knob work just as if you had them from stock? I'm assuming so, but I hadn't kept track if the non-premium headlight models shipped with the same headlight adjustment or not.
J4runner721
J4runner721
Jay
Washington
Thanks! Yes, The headlights can be adjusted through the rolling knob. I kept it around 2-3.
CO/ZA
Denver
25 4R ORP
Is there any material difference besides the aesthetics for these compared to the TRD OR/SR5/TRD Sport trims?
Do they swivel or illuminate better at night?
There is a material difference, but no active steering of light. The only instrumented test I'm aware of comparing the two are the IIHS headlight test, on which the lower trims receive a "Poor" rating and the upper trims receive an "Acceptable" rating.
BonRunner
2026 TRD Sport Premium / WCP
So the difference from other models is light-up "underbrow" as Daytime Running Light (DRL)?
I can't justify $1k+ for this lol..even tho they look nice, just not much functional upgrades..
ngfilla94
Nathan
St. Peters, MO
2025 TRD Sport Premium
Form has lights in the works, but not sure about release timeframe. They're the same ones they had on their Tacoma at SEMA 2024 as prototypes.
Franco
Frank
San Clemente, CA
2025 4Runner TRD Off-Road
Maximus4R
Adam
Nashville
These look amazing, quit holding out on us Form
2025 2026 4runner 6th gen Installed Limited (Premium) Headlights on 4Runner TRD Off-Road -- part numbers & tips IMG_1231
ngfilla94
Nathan
St. Peters, MO
Oops, they had them on their 4Runner this year, too. Looks like they will have a selectable amber or white DRL, sequential signals, and a startup sequence.
Franco
Frank
San Clemente, CA
If I am reading the data right the high beam improvement is very significant
CO/ZA
Denver
25 4R ORP
Sort of, yeah.
10m-30m here and there so 30-60ft distance/spread.
Some difference is noted, given the Acceptable rating vs Poor.
Is that worth the $2,000 investment though....
