Administrator
Administrator
Staff member
Jay
In case you haven't seen these specs in the full specs thread (searchable text PDF version), listing here for easy reference.
6th Gen 4Runner Towing Capacity Specs
Maximum Towing Capacity Weight: 6,000 lbs​
(per SAE J2807 Methodology)​
Fuel Capacity: 19 gallons​
Engine Oil Capacity: 5.9 qt. (with filter)​
6th Gen 4Runner Vehicle Weight by Trim Levels
  • Curb Weight (lbs):
    • Gas Engine (i-Force)
      • 2WD SR5: 4,455 lbs
      • 2WD TRD Sport: 4,610 lbs
      • 2WD Limited: 4,730 lbs
      • 4WD SR5: 4,685 lbs
      • 4WD TRD Sport: 4,850 lbs
      • 4WD TRD Off-Road: 4,850 lbs
      • 4WD Limited: 4,970 lbs
    • Hybrid Engine (i-Force Max)
      • Hybrid TRD Off-Road: 5,225 lbs
      • Hybrid Limited: 5,370 lbs
      • Hybrid Platinum: 5,390 lbs
      • Hybrid TRD Pro: 5,455 lbs
      • Hybrid Trailhunter: 5,500 lbs
  • Gross Vehicle Weight Rating (GVWR) (lbs):
      • 2WD SR5: 6,005 lbs
      • 2WD TRD Sport: 6,020 lbs
      • 2WD Limited: 6,130 lbs
      • 4WD SR5: 6,075 lbs
      • 4WD TRD Sport: 6,395 lbs
      • 4WD Off-Road: 6,240 lbs
      • 4WD Limited: 6,395 lbs
      • Hybrid TRD Off-Road: 6,505 lbs
      • Hybrid Limited: 6,505 lbs
      • Hybrid Platinum: 6,505 lbs
      • Hybrid TRD Pro: 6,505 lbs
      • Hybrid Trailhunter: 6,505 lbs
2025 4runner 6th gen Curb Weight, GVWR, Towing Capacity for 6th Gen 4runner (2025+) Curb Weight, GVWR, Towing Capacity for 6th Gen 4runner (2025+)
qtb007
Quentin
Hurricane, WV
23 GR Corolla
Pretty big hit to the payload on the Pro and Trailhunter, but I assume the additional armor that comes factory is at least partly to blame. Good to see that the non-hybrids are more or less the same weight as the outgoing model with a LOT more torque and gears available. Should improve drivability of the 6th gen considerably over the 5th gen.
waikikeith
Keith
San Diego, CA 92108, USA
2006 4Runner 4.7
Hi. Can someone please explain what Toyota is doing to increase the GVWR from the 2wd SR5 @ 6005lbs to the TH hybrid at 6505lbs? Different wheels and tires / suspension ... but any difference to the frame or brakes? Or is toyota de-rating the GVWR for the lower trims and assigning a higher rating to the higher trims just with no real difference? My thought is, maybe the SR5 4x4 is actually capable of a higher GVWR and thus payload but Toyota is derating them for some reason. THanks!
Hacksaw
az
2025 4runner TRD-ORP
The industry standard definition of payload is:
Payload = GVWR - curb weight
That should be the factory payload on the driver's door jamb sticker, but it's not.
They add a yellow "adjustment" sticker for the per-vehicle port/dealer installed options.
Owners then have to further reduce the payload based on things they add, e.g. roof rack weight, new tires/wheels that are x lbs heavier than factory, etc.
GVWR is a rating given by the manufacturer based on the frame and other considerations for a given model. GVWR cannot be weighed on a scale. It's a determination/calculation, to set a worst-case safe maximum.
So, why are the payloads listed on driver's door jamb stickers too low by hundreds of lbs? If toyota wanted to add "safety margin" they should have baked that into the GVWR. Did they mis-state the GVWR and don't want to admit it? Misprinted door jamb stickers?
2025 4runner 6th gen Curb Weight, GVWR, Towing Capacity for 6th Gen 4runner (2025+) 2025 4runner payload tabl
theo
theo
Blk4runner1960
      • Hybrid Trailhunter: 6,505 lbsi Can’t believe the I-force max almost 500lbs of torque and can only tow 6,000lbs the same as the I-force motor. Can the Land Cruiser tow more
nubbins_
I saw on Tundra forum where they stated this, which is lazy but understandable:
2025 4runner 6th gen Curb Weight, GVWR, Towing Capacity for 6th Gen 4runner (2025+) 1748646137211-w1
But then I opened up the most recent online manual and it all becomes clear that Toyota is just lazy as shit:
2025 4runner 6th gen Curb Weight, GVWR, Towing Capacity for 6th Gen 4runner (2025+) 1748645951102-i
All I can say is, wow. Toyota really does not understand how payload works. Why don't we all just play it safe, call it 500lb for every 4Runner, and call it a day? /s
Better to just go to the scales and weigh things, take those numbers and build in a conservative buffer of 100-200lb, and go from there.
drNick
Nick
Ft. Myers, FL
I’d say I am completely satisfied with my TRD ORP. It has 1390lbs payload and can tow 6000lbs. Still very capable off-road. Way, way better than Broncos and Jeeps all things considered. Except perhaps extreme rock crawling…
Hacksaw
az
Does the door jamb sticker on the newer ORPs now say 1390 (instead of 895 that the earlier delivered models had listed on the sticker)?
gestut
Ronnie
Az
St5
Yeah just got my sr5 4w and it says payload 895 wtf. Is this a a label issue? Its a base sr5. It has yellow sticker of additional 27 lbs..assuming roof rack.
TRD-Ferguson
NJ
2025 TRD Sport Premium
Did anyone ever figure this out? My new TSP says 895 lbs. I think it's interesting that the extra row of seats adds capacity... Wouldn't that add weight? Maybe the sticker value is what they crash tested?
My gas limited 4wd also says 895. It was just delivered to the dealership on the 11th. How do all of these different trims have the same payload capacity, given different curb weights?
strangely the manual says that all 2-row models are 895 and all 3-row models are something like 1160. Makes no sense to me!
