charliemanse
DFW
2025 SR5 4X4
There Falken Wildpeak 285/70/17 load Range E. Got them slightly used on Facebook. Haven’t noticed much in mpg but I also went into it knowing I’m not gonna get great gas mileage so I try not to pay attention to it lol. More about the smiles per gallon for me. I took the air dam off right away but I did a roadtrip to Omaha from Minnesota and think I was getting around 20mpg without the air dam on stock tires. Just checked today after bigger tires for a few days and it’s sitting around 18.5mpg but mostly city driving.
Yep, sometimes you gotta live for the smiles lol. Ok cool, yeah, I’ll be taking off the air dams for sure then. Still looking into the different tire options. Appreciate it!
JBaughman
Joshua
Minnesota
Yeah of course. Definitely looks more like a 4Runner without the air dam too and takes like 2 minutes to take it off in the driveway.
ah4rsr5
Abraham
VA
2025 4R SR5
I also just put 285/70/r17 tires on my stock height and rim SR5. No rubbing at all and rides smooth. Let me know if anyone has questions.
rides smoother than stock tires?
JBaughman
Joshua
Minnesota
I wouldn’t say smoother than stock but stock tires are also highway tires but they’re still very smooth and not a big difference you can just tell you have bigger tires if that makes sense. You do get a little bit more tire noise but not bad. Sacrifices you have to make to have the 4Runner look like a true 4Runner with big tires so it definitely worth it to me.
Reed
Reed
Getting ready to do this…curious if folks are having trouble with this.
romik
Romik
2025 Toyota 4runer
Looks good, I like it and I’m planning to do the setup. My only concern is that technically, when upgrading to 285/70R17, we need to use 17x9 rims ( OEM is 17x7 inches ). Otherwise, experts say sticking with OEM rims will cause sidewall bulge and uneven wear. Have you taken this into consideration?
ah4rsr5
Abraham
VA
2025 4R SR5
I've heard the same but people have been doing it on the forums here... Not sure what they think tho
stephbm6
Salt Lake City, Utah
I put the Mickey Thompson 285/65/18 E load rating tires on mine. The road noise difference was not even noticeable. It has a slightly rougher ride but very minor difference. any upgraded C load rating in my opinion would have basically no difference in ride comfort.
Do you have any rubbing with the 285/65/18 tires?
danimaldaisy
San Bernardino
6th gen trd sport
I ran 17” pro sema wheels with the same width. Absolutely no issues specifically with the K02 after almost 30k miles.
gestut
Ronnie
Az
St5
Worh
gestut
Ronnie
Az
St5
With the tire size and weight increase. Do you guys notice performance degradation
danimaldaisy
San Bernardino
6th gen trd sport
that depends. The new 4 runner was designed to run 33’s. Just compare your model to another on Toyotas website. As far as weight you would need to see how much an 18 inch wheel with the stock mounted tire would weigh. Me… I’m sticking with c rated bfg in 285/70/17 which is 55ish lbs. that and a lightweight wheel might not weigh that much more than a stock 33. If you choose a tire that’s only available e rated they can almost weigh 70lbs. Just keep that in mind.
gestut
Ronnie
Az
St5
Got it .I will check. Also do all trims have the same gearing final drive etc
