Fishing
New York
Has anyone mounted the rear dash cam yet? does the 5th gen mounts work?
Updated with install info & pics by @jaymay82 (from his posts below)
I did the @Wolfbox G900 pro with the rear camera mounted on the exterior just under the liftgate spoiler.
This is the video I watched on how to do the rear camera install on the exterior. Not my video.
Mounted slightly off to the driver-side to be away from the rear wiper, and also slightly towards the rear glass so that there's some coverage from direct sunlight and rain hitting the lens. Unlike the video, I simply used the included double-sided tape for mounting. Eventually I will utilize the screw and locking nut method used in the video.
Removing the spoiler is easy, just open the rear gate and there's 4 round rubber covers with i believe 10mm bolts inside. Remove the 4 bolts and the spoiler lifts up enough (don't have to remove it like the 5th gen video) to run the cable and follow the video instructions on running it through the existing cable bundles and into the cabin.
jaymay82
Honolulu
I did the @Wolfbox G900 pro with the rear camera mounted on the exterior just under the liftgate spoiler. There's a 5th gen video on youtube and the 6th gen pretty much followed the same steps. I will say the spoiler on the 6th gen was easier to remove than the 5th gen for running the camera wire.
zgreen
Zach
I did the Wolfbox G900 pro with the rear camera mounted on the exterior just under the liftgate spoiler. There's a 5th gen video on youtube and the 6th gen pretty much followed the same steps. I will say the spoiler on the 6th gen was easier to remove than the 5th gen for running the camera wire.
Very cool. I was thinking about how to do that myself. Would you mind posting a few pics of the setup under the spoiler? Thanks in advance.
Hacksaw
az
2025 4runner TRD-ORP
I have a 3 camera system but haven't mounted the rear camera yet. Mine has to be mounted inside so I'll need to find some sort of bracket (and the lens has to hang down a bit lower than the top middle of the rear window due to the windshield wiper pivot point being in the way at the very top).
For routing the cable for the rear cam, I'm wondering if you can remove the ceiling console panel and insert a fish rod or tape that will make it all the way to the rear headliner trim above the liftgate so I could then attach a pull string to it and pull a much shorter USB-C cable front to back, down the middle of the roof, without all the prying and wedging that you need to do when you route the rear cam cable along the sides above the top of the doors and pillars. Anyone tried that (no moonroof on mine)?
Gastan
Tacoma TRD Pro
Yes some pics please. I'm interested too. Thx
jaymay82
Honolulu
2025 2026 4runner 6th gen Rear Camera Dashcam Mount w/ Rear View Mirror Install - DIY Instructions & Pics rear camera dash cam installed 2025 4runner 6th gen 1
2025 2026 4runner 6th gen Rear Camera Dashcam Mount w/ Rear View Mirror Install - DIY Instructions & Pics rear camera dash cam installed 2025 4runner 6th gen 1 copy
2025 2026 4runner 6th gen Rear Camera Dashcam Mount w/ Rear View Mirror Install - DIY Instructions & Pics rear camera dash cam installed 2025 4runner 6th gen 2
zgreen
Zach
Thanks!
jaymay82
Honolulu
For those that are ok with mounting the rear view camera inside the cabin, there is a mount that utilizes the plastic push pin in the headliner to hold the mount to the ceiling, along with double-sided tape. I was considering this option, but i've read the rear glass tint and rain drops provided a lower quality view versus mounting the camera on the exterior.
https://www.amazon.com/dp/B0DF5WD7VX?ref=ppx_yo2ov_dt_b_fed_asin_title
jaymay82
Honolulu
Update:
I did end up reinforcing the mount for the rear camera using the method in the youtube video. Went to my local hardware store and found a screw, washer, and nut; and now the camera is very secure.
One thing to note, this morning i suddenly have no signal coming from the rear camera. It doesn't even show up on the screen as if it doesn't exist. Checked all connections and I had even sealed the reverse wire after reading all the comments online about those who do not connect the red reverse wire being exposed and triggered by moisture. I've emailed @Wolfbox customer service and will see what happens...
Wolfbox
Florent
Toyota 4runner
Update:
Please wait for the reply. They will help you solve the issue. If you need anything, please DM me.
jaymay82
Honolulu
Customer service was great and fast! Turns out the video connector plug came loose due to the cable being run too tight. Made some adjustments, resealed the plug with electrical tape, and BOOM, back up and running! All good ?
I will say that there was no hesitation for them to ask if I needed a replacement. They stand by their products.
Wolfbox
Florent
Toyota 4runner
Great to hear that your issue was addressed. We always support our customer like they support us! ?
Geofflolz
Geoffey
Graham WA
2025 Toyota 4runner SR5
I am having a crazy time trying to get the spoiler / back plastic off. Does the black plastic on the outside just pop off with clips? Or do I need to remove the spoiler? Ive gotten a few things to loosen up on the plastic itself but going into the corners feels like its gonna snap.
Also I am assuming you mean the 4 bolts on the spoiler under the rubber covers and then the other bolts? Tried just doing the 4 under the covers and that thing is still on there lol.
Thanks in advance! Trying this install as we speak.
jaymay82
Honolulu
The black plastic piece just under the rear wiper pops right off. Start by pulling down (gently) with the lift gate closed, the right side of the piece just under the wiper motor.
For the spoiler, after you remove the 4 bolts located under the black rubber grommets, it give it enough opening to run the cable through. You don't have to remove it in order to run the cabling.
