Humming / Increased Road Noise after lift & tires?
KRunner
PA
2025 4Runner Off Road Premium
What kind of increases in tire & road noise is everyone seeing after installing lifts & different tires on the 6th gen? Are there ways to reduce or mitigate?
I installed 285/75r17 Toyo Open Country AT3 tires (load range C) on Method MR318 wheels. Complimented by the Westcott Pre Collar lift.
Immediately noticed a fair increase in road noise. Honestly, it’s been more than I reasonably expected, but I’m starting to wonder if this isn’t all from the tire change. Possibly other variables at play. Curious what everyone else is hearing & feeling?
P.S.- Of course I had to remove the front air dam for aesthetic purposes. So that’s a variable as well with increases undercarriage air flow & turbulent air.
Rellims
Sean
ORP - Underground
I moved to 275/70R18 Wildpeak AT4s and didn't notice too much of an increase. On a road trip the biggest noise factor I found was closing the sun shade on the moon roof at high speeds.
KRunner
KRunner
PA
Good to hear! & that’s a good point.
Any lift?
Starting to think the additional noise I personally hear (mostly highway speeds) is more so due to the lift & not the tires.
Rellims
Sean
ORP - Underground
Any lift?
No lift…yet
risurfstyle
James
New England
2025 SR5
Any lift?
I changed out tires to 265/70R17 Falken Wildpeaks on my SR5 from 245/70R17 stock. Definitely noticed a slight increase in noise but not bad. I also removed air dam. I went modest with tire size/beefiness (1.3" more diameter) as I was concerned about noise myself. I'm sure as you add up the mods it's going to cause more noise, but I have no idea if that's normal or can be mitigated. Maybe add sound dampening materials in the vehicle?
KRunner
KRunner
PA
Great points. Since it was done all at once in my case, it’s likely all adding up & not just one mod that’s the root cause! Not complaining. I knew it came with the territory but started to question if it was normal or if what I am hearing is out of the norm.
I’m considering throwing some dynamat in the front wheel well area & floor boards.
I heard good things about the Wildpeaks (AT4W?) especially with how smooth & quiet they are for an AT.
time2playandy
Utah
Are your new tires the LT version? If so, how’s the ride quality on-road? Thx!
J4Runner1
James
I have the same 4R and about to do some of the same mods - Westcott Lift, 285/75R17.
Any updates?
Also, dId you notice any major changes with mpg and ride quality. It seems like people with the Westcott Lift and C load tires and reporting better ride quality.
Any problems with cruise control or lane sensing?
Thanks.
mallcrawler42
Antony
OR
2025 4Runner TRD Off Road
Any updates on this? I recently installed my lift kit and I noticed what seems to be increased tire noise but these are the same tires I had before which were silent quite literally that same morning.
every component connected between the rubber and vehicle body
transmits sound differently. what specific pieces were installed to
lift it ? that is one reason tire noise can change.
