E.T.
Orlando area
2025 4Runner Off-Road
kinetic262
Dave
PA
Ericd6972
Delaware
2025 TRD ORP
W
Wondering if the dealer just swapped out the tires then, since those aren't stock.
If you look at the thread, the truck has a leveling kit. There are mixed reviews on this tire size fitting without rub. Some have had no issues, others rub.
kinetic262
Dave
PA
Sorry, I was referring to the 4Runner, not the Tacoma.
olefriend
TX
Another Ice Cap TRD Off-Road Premium ORP on the TRD 18" Wheels / Falken Wildpeak AT3WA
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos  Ice Cap TRD Off-Road Premium ORP on the TRD 18%22 Wheels : Falken Wildpeak AT3WA 1
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos  Ice Cap TRD Off-Road Premium ORP on the TRD 18%22 Wheels : Falken Wildpeak AT3WA 2
Memory Lane
Jeff
Duxbury, MA
Website
loveforlaney.org
2021 Sequoia Nightshade & 2025 4Runner TRD Pro
These don’t appear to be exactly same as the factory wheels from the TRD Pro. Very similar though.
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos IMG_6875
Gastan
Tacoma TRD Pro
Correct, different wheels. I posted this info in another thread:
The upgrade option wheels being covered in this thread are called "TRD 18" Wheels" and the TRD Pro wheels (on the TRD Pro model) are called "TRD Pro Wheels"
Here's specs for the TRD Pro Wheels:
TRD PRO Flat Black 18" Wheel - Toyota (PT946-35240-2F)
PART NUMBER:
PT946-35240-2F
PRICE:
$285 MSRP ($223 online)
COLOR:
Flat Black
DIAMETER:
18"
FINISH:
FLAT BLACK
OFFSET:
+20 mm
Wheel Hub Diameter:
Ø95
WHEEL NAME:
WHEEL WIDTH:
8.5"
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos 012-2024-toyota-tacoma-trd-pro-2
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos 63d8505ef99c83f14918335e439795be-
Ericd6972
Delaware
2025 TRD ORP
PART NUMBER:
PT946-35240-2F
PRICE:
COLOR:
Flat Black
DIAMETER:
18"
FINISH:
FLAT BLACK
OFFSET:
20 mm
Wheel Hub Diameter:
Ø95
WHEEL NAME:
WHEEL WIDTH:
8.5"
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos {filename}
Really wish the TRD wheels were similar offset? need to run a 1" spacer to match that look.
Ericd6972
Delaware
2025 TRD ORP
So I pulled the trigger on some 33" Nitto Terra Grapplers tires (replaces the Falken Wildpeak AT3WA that comes with 18" TRD Wheels package upgrade). At first I wanted to go 34" with a 285/70r18 but there were not many options for the 18" wheel. Most were E load and the only nice C load I could find were the Wildpeaks but they are Heavy! 70lbs per tire.
That being said this is my wife's car, I did not want to run the E load or the heavy tire so I chose to go with a 33s and I am happy. It drives very smooth on the highway with minimal noise and I like the way it looks for now but might add a lift in the future.
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos beforewildpeaktires
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos afterwildpeaktires
Cityzen10
Ryan
Gresham OR
Mickey Thompson Baja Boss A/T
285/65/18 (33.2" Dia)
Wanted to try the wider and slightly bigger diameter Mickey's on the stock suspension and upgraded TRD 18" Wheels (+45 offset) to report if there will be any rubbing for this tire size. They fit great with no rubbing.
I'd like to maybe put some +35 or +25 offset wheels on it but I'm not in a huge hurry as they look pretty good. I think some +35 - +20 wheels will give a good poke but will rub a tiny bit without a leveling kit, lift kit, or at least pushing the front wheel well felt forward and removing the rear cover and bracket. Any of these options should do to eliminate rubbing should you choose a wheel with more poke and these wider tires.
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos 20250315_154549
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos 20250315_152005
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos 20250315_151953
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos 20250315_151913
2025 2026 4runner 6th gen 18" TRD Wheels upgrade on TRD Off-Road Premium (on Falken Wildpeak A/T3WA tires) - Photos 20250315_151930
theo
theo
Blk4runner1960
Here's a first look at the TRD 18" inch wheel factory upgrade option on a TRD Off-Road Premium ORP. The tires are Falken Wildpeak AT3WA.
This great looking 4Runner belongs to Josh L
Official description of 18" TRD wheels:
  • These 18-in alloy wheels with the TRD logo center cap throw down while styling up.
  • Off-road race-inspired 18x8" cast aluminum wheel with 6 lug nut pattern
  • +45 mm offset
  • $1,325 MSRP ($925 dealer cost)
More info:
PART# PT946-35240-2F
18x8.5 139.7 6 lug
TRD 18" wheels are available for $300 MSRP per wheel. But much lower from some dealers -- this one selling for $215 per wheel. [Part number PTR56-35242-F1]
PART# PT946-35240-2F . They are 18x8.5 139.7 6 lug and I've confirmed they will fit
https://parts.elmhursttoyota.com/oe...5YM4P0CMbMKe44Uo6oLDM_C1Qgcz3_RupVz6fFcNpH8M-
More of the black 18" TRD wheels upgrade on another Underground TRD Off-Road Premium ORP
You showing the same wheel in 18” on the suv and in the catalog? If so one said 8” wide other 8.5 wide 45mm offset correct?
rutsnext
British Columbia
2025 4Runner ORP
  • +45 mm offset
More info:
PART# PTR56-35242-F1
18x8.5 139.7 6 lug
PART# PTR56-35242-F1 . They are 18x8.5 139.7 6 lug and I've confirmed they will fit
Anyone know if the center cap on the stock ORP wheels will fit this TRD upgrade wheel? (PTR56-35242-F1 +45 offset). The center caps are backordered.
JR1
Joe
Missouri
I think they are the same size but a little different look.
LegRunner
Maynard
2020 Grand Cherokee Trailhawk
  • +45 mm offset
More info:
18x8.5 139.7 6 lug
My dealer is really trying to rip me off. Yes I'm in Canada, but they are trying to gouge me over 2k for those wheels.
adVic
Ontario, Canada
2025 4Runner TRD ORP
I can’t guarantee anything but look around at different Toyota dealers. I noticed one in Brantford and 2 in Alberta that were offering reduced prices on parts (I was looking at cross bars and skid plate, not wheels but maybe?). Even after exchange we’re still getting about a 15%markup from prices in original message.
