Marie_ARB
Marie
Seattle, WA
Are you planning on building out your 6th gen 4Runner for camping trips or longer expeditions? Maybe you've already got a bucket list of trails you want to hit now that you've got a capable rig. If that sounds like you, suspension should be the first upgrade on your list.
Upgrading your suspension makes all the difference between a truck that just carries your gear and one that actually handles well with it loaded up. Not sure what suspension kit to get for your 6th gen 4Runner? Don't worry, we've got the answer: Old Man Emu's MT64. Here's why.
Why Suspension Comes First
Here's the problem: every accessory you add to your build, bumpers, drawers, a rooftop tent, extra fuel and water, adds weight, and that weight slowly compresses your stock suspension over time. The result is sag, a harsher ride, and less control right when you need it most. Suspension is the first upgrade because it's the foundation everything else on your build sits on.
That's exactly what the MT64 is built to solve. Old Man Emu tunes and matches the springs, shocks, and arms (if you choose to upgrade) in each kit around how your 4Runner is actually going to be outfitted, so instead of adding weight and hoping for the best, you're running a suspension that's already accounted for it.
About the MT64 Shocks
The MT64 shocks sit right in the middle of the OME lineup, between the iconic Nitrocharger and the ultra-high-performance, adjustable BP-51. They're built with a huge 2.8in aluminum body, giving them the oil capacity and heat dissipation to handle everything from daily driving to demanding overland trips. The name comes from the internal monotube design, which uses a 64mm (2.5in) inner bore diameter, big even by MT64 standards, and it's specifically engineered for vehicles carrying campers, toppers, tents, and rack systems.
Features & Benefits
  • Tuned and matched suspension kit for increased comfort and control
  • Complete coilover assembly for direct bolt-in fitment
  • Adjustable 6-position snap ring, giving a range of front lift from 1.75–3in depending on how you set it
  • Monotube design with a massive 2.8in body for more oil and more accurate tuning
  • Aerospace-grade aluminum body dissipates heat roughly fifteen times faster than steel and adds protection against stone damage
  • Forged body cap and rod ends reduce weight while keeping strength up
  • Digressive valving reacts instantly to changing surface conditions
  • Direct replacement for stock and most aftermarket lift kits
  • Hydraulic end-zone top-out adds cushioning at full extension to help soak up unexpected hits
  • 7/8in piston rod shaft for exceptional stability under load
In short: a bigger body means more oil, better heat management, and a more refined ride, whether you're driving to work Monday or out on the trail Saturday.
Kit Options for the 6th Gen 4Runner
We've built this out so you can go as light or as full a build as you need:
Complete Kits
Individual Components
If you're not sure which combination fits your build, the short version is: figure out your loaded weight front and rear first (bumper, winch, drawers, RTT, etc.), then pick the kit that's tuned to hold that weight.
If you need help, drop your build in the comments, and we’ll help you figure it out!
About the Upper Control Arms
Your 6th gen 4Runner runs an IFS (independent front suspension) setup, meaning each front wheel moves independently instead of both sides being connected by a solid axle. The upper control arm is a key part of that system; it connects your frame to the front wheel hub, and it's a big part of what keeps your front end aligned and handling right, on- and off-road.
The problem is, when you lift the front of your 4Runner, it changes that geometry enough that a shop can't always get you back into proper alignment spec with the stock arms. This can cause other issues down the line. But, OME's Upper Control Arms fix that by giving you the adjustment range you need at your new ride height, so your alignment can actually be corrected instead of running out of range.
Want more information on whether you should upgrade your UCAs? Let us know!
Bottom Line
If you're building a 6th gen 4Runner and haven't done anything yet, adding suspension is the upgrade to start with. Everything else on your build, bumpers, a winch, drawers, a rooftop tent, is going to load onto that suspension, and the MT64 is tuned to carry it without turning your 4Runner into a bouncy, saggy mess.
Got questions about which kit fits your build, or want a hand figuring out loaded weight estimates? Drop them below.
3rdRunner
Bill
Quick question about added weight. I have TH, running stock OME w/preload collar (+2.5”). With aftermarket bumper and winch carrying approx 115-120 lbs up front. Do you know how much additional weight the stock OME setup is designed to carry? I put DBF17T on LC250 tower to help cushion up travel, but a little concerned w/sagging and impact to droop with preload collar. Considering switching out stock OME to MT64 with heavier spring. Used current setup off road a lot and I’m getting by - concerned about long term.
zcmack
las vegas
are those new silver control arms for this platform? every other version i've seen shows tubular UCAs, as do the links above.
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Is there an added weight version of the MT64 coming out? Will BP-51s fit a 2025 4R TRD PRO?
4funner
Adam
Missouri
Prius and 4runner
ARB likes to show a lot of products you can't buy lol. I think ARB has been posting pictures of this built 4runner for over a year at this point but still hasnt released a skid plate, bumper, or roof rack shown. Also it doesn't look like they sell an aluminum UCA for any vehicle.
PearlyGates
Shane
AL
I have the MT64 on front and rear on my 2026, and for the most part, I've been pleased with the ride quality both on and off road. The aspect that I'm less than pleased is the drop on the front end with the added weight of bumper, winch, lights, ~180 lbs. I'm fairly certain with the current MT64 offering for the 4Runner, 3 inches of front lift can only be attained with no front load or 0 lbs as ARB has indicated on the parts listed below (single coilover and kit).
MT64 COIL-OVER FRONT MT64996013
Complete coilover assembly allows for direct bolt in fitment, and providing 3in of lift on vehicles with stock to 220lbs of front end weight
MT64 KIT FR 3 IN/0 LB 2136K
This suspension lift kit is tuned and matched for the Toyota 4Runner to provide 3in of lift in the front, with a weight of 0lb.
I believe the statement in the original post regarding "figuring out your loaded weight" is misleading because per their website, ARB only has one weight offering of 0 to 220 lbs. What's interesting or maybe frustrating is to go research the offerings for the Tacoma and Land Cruiser, both have a 220-330 lbs front load rating and 440 lbs rear load rating.
I've submitted a help ticket to determine the part number for the heavier Tacoma front spring and inquiring as to any reason why I can't install this spring on my 4Runner.
3rdRunner
Bill
I noticed that - the 0 load. I think you can go to other suppliers and have them build one with the heavy weight springs. Maybe SQR Fabrication? That’s my concern with the stock TH OME - overloading it with bumper/winch.
PearlyGates
Shane
AL
Response from ARB which totally refutes the original post:
Thanks for reaching out to us. Unfortunately, at this time we do not have a heavy spring for the new 4Runners. We are expecting them by the end of the year, October-November time frame.
4funner
Adam
Missouri
Prius and 4runner
I guess their AI advertising makes some mistakes. I put their post into the AI detector, here is the result lol.
ElonMuk
Keith
Phoenix, AZ
2025 Toyota 4Runner TRD Off-Road i-Force Max
I talked to ARB at Overland Expo West a few months ago. They said those new UCA's will be out likely toward the end of the year. They are still testing them out and making final tweaks before releasing them.
Marie_ARB
Marie_ARB
Marie
Seattle, WA
Hello,
At this time, we do not have release dates for any new suspension kits. We will be sure to post once we have more information!
Marie_ARB
Marie_ARB
Marie
Seattle, WA
Hello,
Thanks for reaching out!
You are correct. Currently, the 6G 4Runner MT64 kit is only offered in the 0-220 lb front range, so the full 3" is only guaranteed at the lower end of that window. But we are working on changing this and should have more options by the end of the year.
We wrote this forum post to be a conversation starter. For many people, buying a suspension isn't a quick process, and there are often questions specific to their build/goals. We're here to help answer those. So yes, we wanted to make clear that understanding your loaded weight is a step in the suspension decision-making process, even if we only offer one spring option right now.
The 6G 4Runner came out a little over a year ago, and we're working hard to produce the best suspension kits for these vehicles. That may take a little more time, but we promise it's worth it.
If you have any other questions or need help with your build, let me know! It sounds like you could benefit from upgraded front springs once we have that option available. And don't worry, I've already reached out to our team to get a timeline on that.
Marie_ARB
Marie_ARB
Marie
Seattle, WA
Hello!
I'm working on getting an answer on how much added weight the TH suspension can handle. I will post an update when I have more information!
Marie_ARB
Marie_ARB
Marie
Seattle, WA
As stated above, we are hoping to help all 6G 4Runner owners understand the process of selecting the right suspension setup for their build. Yes, we do not have the heavy-duty springs, but we are hoping to have them by the end of this year, and when that comes, we'll tell you the same thing: understand your load weight before selecting a suspension kit.
This post was not meant to confuse anyone, and I apologize if it did. We are hoping to inform everyone so you can make the best decision for your build, and we appreciate your patience while we get these options finalized!
