vready
Vince
Hood River, OR
In a previous post, I described how I built my 2025 TRD Off-Road Premium iForceMAX 4Runner to be a self-sufficient adventure vehicle for extended, multi-day camping and overland/off-roading trips. I equipped it with a Dometic CFX3 45 Electric Cooler which runs off 12v DC, along with other 12v accessories that make camping trips comfortable and convenient.
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A6772
To power my accessories while in camp, I was looking for a dual-battery solution that would do the following things for me:
  • Power my refrigerator and other accessories for extended stays (1024Wh capacity)
  • Recharge using the hybrid charging system and augment my 12v starter battery
  • Allow everything to run off shore power, when AC hookups are available
  • Efficiently recharge the auxiliary battery whenever the engine is running/idling
  • System that is simple to configure and monitor without a lot of complexity
  • Doesn’t require major vehicle modifications or diminish cargo carrying capacity
  • Ability for the auxiliary battery to recharge or jump my starter battery, if needed
  • Allow solar charging of the auxiliary battery for extended stays in one location
  • Can be unplugged and removed from the vehicle in 30 seconds when not needed
After researching various options, I went with the EcoFlow Delta 3 Plus Portable Power Station. I like it because it’s compact, has convenient output ports for AC/DC/USB, meets all of my functional requirements, and comes with a great iPhone app which allows me to monitor and control everything in one place.
In addition to the Delta 3 Plus, I’m using the EcoFlow 800W Alternator Charger, and the EcoFlow 220W Bifacial Portable Solar Panel.
Here’s an overview of how the entire system is wired:
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner Ecoflow System Diagram
* Yes, I know most hybrids don't have an alternator. It represents the vehicle charging system (DC-DC converter).
Here’s how it’s installed and how I use it:
The Delta 3 Plus fits nicely behind the passenger seat in the rear footwell. Whenever it’s installed in the vehicle, I run a short, 2-foot TrippLite Series 15 Amp power cord from the EcoFlow into the 2,400W AC outlet in the center console for charging. This allows me to turn on the AC 120V switch and charge the Delta 3 Plus using the Toyota hybrid charging system whenever the engine is running.
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A4999
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A4991
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner 1781737933701-o2
Next, I installed the 800W Alternator Charger under the driver seat. I connect the charging input labeled “Battery” to the Delta 3 Plus using the provided cable, and I ran the other cable labeled “Alt In” to the Odyssey AGM48 starter battery in the rear cargo area by routing it under the door sill covers and behind the plastic side panels.
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A3072
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A3080
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A3854
When I’m in a developed campsite with electrical hookups, I use this GE 3-outlet Power Strip Surge Protector 15ft Extension cable, which is rated for 13Amps / 1625 watts, to connect the EcoFlow to shore power. I simply unplug the AC cord from the Toyota 2400W outlet, and plug it into the extension cable.
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A3860
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A2939
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A2941
I don’t use the solar panel very often (because I’m usual driving from place-to-place enough that I can just charge off the alternator), but when I need it, the 220W Bifacial Solar Panel plugs right into the Delta 3 Plus and is very compact and easy to stow. Since I have a Free Spirit Recreation FSR Aspen V2 Rooftop Tent with a clamshell closure, I can just stow the solar panels inside the RTT when I’m not using them.
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner 220W Solar
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner _W0A3863
Here’s a look at the EcoFlow iPhone app and Apple CarPlay widgets:
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner EcoFlow A
The app for the Delta 3 Plus shows the input and output draws, the current battery charge level, and the expected run-time based on recent usage patterns. You can also selectively turn off AC, DC and USB ports, as needed.
The Alternator Charger has three modes:​
Charge: charges the EcoFlow using the vehicle’s charging system at up to 800W​
Reverse Charge: Allows you to recharge or jump the starter battery using 800W​
Battery Maintenance: Used for off-grid basecamps to prevent the starter battery from dying while running 12V accessories.​
The EcoFlow Carplay app allows you to control and monitor the Alternator Charger right from your dashboard. You can turn it on/off and toggle between charging and reverse charge modes.
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner IMG_2521
Here are some things I really like about how it all works together:
  • The EcoFlow can charge from the 120V outlet or the Alternator Charger— or both
  • The combined 1200W can fully recharge the EcoFlow in about 45 minutes
  • On shore power, the EcoFlow delivers pass-thru power to all connected devices
  • The Alternator Charger can charge the EcoFlow, or reverse charge the starter battery
  • The Battery Maintenance feature prevents my starter battery from getting too low
  • The iPhone app and CarPlay widget provide useful and detailed real-time data
  • My Dometic fridge can run for 2-3 days straight on a full charge while off-grid
EcoFlow has some promotions running right now with discounts on the 800W Alternator Charger, and bundle pricing when you buy the solar panel or Alternator Charger with the Delta 3 Plus.
mfoga
r4unner
Have you found any issues with the drawing to much power from vehicle battery at any time? Can you just disconnect the cable for charging device to remove battery when not is use?
This might work better than my setup.
Delta 2 plugged into the AC port and also have a solar panel mounted to the RTT. The problem is I would I forget to plus the stupid button.
vready
vready
Vince
Hood River, OR
No issues with the the 800W Alternator Charger drawing down the starter battery. It just gets charged by the alternator (or DC-DC Converter) when the engine is running and doesn't have any draw when the engine is turned off. You can also set a trigger voltage in the EcoFlow app (the starter battery is typically at 12.4v when it's charged, but reads 13.9-14v when the charging system is active) which turns the Alternator Charger on when the vehicle starts.
One thing I didn't mention is that I power camp lights and run power to my rooftop tent, and a few other accessories off my starter battery using a SwitchPros 9100 switch panel, so that is what tends to slowly drain my starter battery while I'm around camp.
The "Battery Maintenance" mode on the EcoFlow 800W Alternator Charger takes care of this by reverse charging the starter battery to sustain those 12v accessories (in addition to the ones plugged directly into the Delta 3 Plus) and keep it at a healthy voltage. The SwitchPros also has a user-defineable cut-off voltage that you can set to prevent those accessories from over-depleting the starter battery.
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Similar setup but using Bluetti Charger 2 and DC hub. Mine is installed in the back.
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner IMG_9120
LostInAZ
Carlos
2026 Toyota 4Runner ORP
We've been using a Delta 3 Plus (2048W) AND a Delta 3 Ultra (3072W) during our trips. We charge them with 4 220W Bifacial panels. We may get a 48v 100Ah battery to top them off instead of recharging the Deltas via the panels since I can take all 4 panels to charge the battery while I can only use 2 panels on the Delta Plus while only 3 on the Ultra.
Probably the best investment we have made for camping so far. Cold nights are so much more comfortable with electric blankets and boiling water in the morning for coffee is super fast. The kettle and the hot plate are super heavy power hungry so Ecoflows are great for them.
BonRunner
2026 TRD Sport Premium / WCP
Too many Amazon affiliate links & broken Ecoflow affiliate links. This post feels like a paid-promo shill, not authentic. Would be better if u don't post affiliate links to any products but instead post pictures & name of them. If people interested, they can search on their own.
mfoga
r4unner
I kind of agree but there are so many threads where there are asking for links over and over so….
vready
vready
Vince
Hood River, OR
Yeah, the 800W Alternator Charger starts up automatically, so you don't have to remember to "push the button" every time. :)
ropdykex11
Rich
Portland, OR
2025 4Runner TRD Off-Road
love the write-up, I will be pursuing a very similar system.
one question, this power panel you have installed near the battery:
2025 2026 4runner 6th gen Dual-battery setup for the Hybrid 4Runner 1782149705173-xr
what is it, how did you set it up, what else can you say about it?
also, I see you upgraded your vehicle battery as well. any particular reason?
vready
vready
Vince
Hood River, OR
one question, this power panel you have installed near the battery.
It's the Blue Sea Systems 12v power panel. I use it to monitor starter battery voltage on its OLED display, and to add some additional 12V/USB charging ports in the rear cargo area. You can read more about it here:
https://www.4runner6g.com/forum/threads/blue-sea-systems-12v-power-panel-install-in-orp-hybrid.4046/
Yeah, I run quite a few accessories off the 12v starter battery around camp (scene lights, phone charging, power to the rooftop tent for light and charging) so I upgraded to the Odyssey AGM48 battery. It takes more charge and lasts considerably longer than the OEM flooded battery. Also better-suited to running the WARN winch.
vready
vready
Vince
Hood River, OR
This post is based on my real-world experience and my specific use case. All photos are mine, and my goal is simply to share my experience with the 4Runner6G community. I just returned from a 10-day road trip on Vancouver Island using this system every day, which is what solidified my thoughts and inspired me to share this post. Take it or leave it...
ropdykex11
Rich
Portland, OR
OP is a well-known member of the community (nearly a year longer than you), with more posts and engagement than yourself, and gave a lot of great insight.
OP named and linked everything so you can look into it yourself, no one is making you purchase anything.
Negativity for no reason!
talmadge
Timothy
SLC, UT
My brother in law works for a camping equipment company and gave me one of those 12v fridges for free. I had been very curious about trying one but was afraid to actually spend the money. I bought a Bluetti AC70 to power it (768Wh) when the 4runner is off because it was one of the best ratios of Wh/price I could find. I was afraid the setup would be cumbersome or fiddly and didn't want to spend too much money on trying it out. Best investment ever. You really can't beat having ice cold drinks or keeping your perishables cold without having to fool with ice. It's played a large part in my girlfriend and I going camping much more this summer than we usually would. My only regret is not getting a higher capacity battery. Bluetti has a 3KWh model now with 2400W output that would let us also power the electric griddle and electric kettle without having to crank the 4runner when our camping neighbors may still be asleep.
Thank you for the write up, I have just been charging mine from the A/C outlet and it's pretty fast at 500W but now I want to investigate the alternator charger as well. Anybody thinking about doing a setup like this should go for it. The fridge takes up quite a bit of space in the 4runner but it's something I would never consider going camping without now.
