Do you think it's too bright? Trying to decide on that or 720 version. Thanks!I also upgraded the rear dome light. But I went with the 1280 lumens version. Agree, it's much, much better (brighter) now. I think this should have been something already provided from the factory (as OEM) rather than the miniscule rear dome light with the two LEDs.
I think it's going to depend on individual preference. I've always felt that the cabin lights in my previous vehicles were always too dim to look for anything in the cabin at nighttime. So, I like the cabin dome light to be much brighter. The 1280 is what I was looking for. But, it sounds like you have some hesitation about the 1280 being too bright. You may want to go with 720 then. I think the 720 or anything with greater lumens will be a huge improvement over the factory rear dome light. The factory dome light only had 2 LEDs...anemic lighting.Do you think it's too bright? Trying to decide on that or 720 version. Thanks!
You run the fridge into the vehicle directly?
Yup, added a 12v outlet directly on the 12v battery and plug the fridge into it.You run the fridge into the vehicle directly?
Are those the TRD Pro wheels with 20 mm offset? I'm thinking of doing the same setup. I already have the Pro mud flaps.New wheels & tires. Pro wheels + 275/70/18 Falken AT4W. Had to removed front mud flaps due to rubbing at turns.
May get Pro mud flaps that are wider & slimmer. Anyone rock that currently with large tires?
Yes, they are.Are those the TRD Pro wheels with 20 mm offset? I'm thinking of doing the same setup. I already have the Pro mud flaps.
