Roof Top Tent (RTT) Suggestions
ChasingTrail
Taryn
Ozarks
I have the kali king and I only keep it on when we are camping and about a week or so after because I’m lazy. Just be aware of mounting to low profile racks. That’s the biggest challenge. I bought van ultra mounts and had to modify to make it work.
The tent is amazing. I’ve never had one that I’ve enjoyed this much, full stop. You definitely know it’s there though, it’s heavy and not aero at all
Seconding the low profile racks/RTT issue... my husband mounted mine last week on the WD rack, and it took him HOURS because he couldn't get to the brackets for mounting. He's a heavy equipment mechanic, so thankfully he's able to weld something to work, but definitely something to be aware of.
mfoga
r4unner
The first time can be a pain to mount. I have 4 sets of Sherpa 1” mounts on my westcott low profile rack. It took a lil bit to get to set but after set I can take if off or install in like 20-30 min tops. Front set are accessible from the moon roof so that’s super easy. The middle sets are on one bar which I remove or attach that makes it easy, 4 screws from outside. It’s a lil harder with the big awning to get to one side but have a nice tool that makes it easy. Back set are second to last bar. I can get the nut started before lowering it all the way and then use a long ratcheting box wrench to tighten it or if I’m lazy remove the last bar.
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
How would this be done without a moon roof for access ?
mfoga
r4unner
Honestly I would probably pull the front bar and fairing.
Prinsu also have a mount that could be easier but only works with some tents. It’s allows you to have nut started for attachment to bars and they should be angle to use a long ratcheting box wrench. The nut they use to attach the foot to the tent uses a nut and the nut doesn’t work with the tent i have. It has to fit a specific size nut.
spyder40
Indiana
2021 4Runner ORP
Have a Sherpa rack and bought a couple extra crossbars. Mounted them to the bottom of my Smittybilt RTT. Biggest pain is getting the RTT up there (2 taller people) then it just drops onto the rack and bolts into the crossbars. Simple
tanman
Tanvir
PA
26 4runner TRD Off Road Prm
I have a 4Runner 2026 TRD ORP and want to get the topoak galaxy pro, will my OEM rack / cross bar be able to handle this weight? Ideally looking to have myself and my significant other sleep up there. Any suggestions?
sscarter
Steve
Massachusetts
2019 4Runner
Thanks for the replies! Makes sense. The comment about cooler is likely accurate--not so good though if it is cold out! I do get the elevation being a great place to be...I like sitting up high too. But if I am my tent I am not likely doing that. Now sitting on a chair on the roof with a canopy for the sun I can imagine!
I'll add another reason for a RTT vs. tent -- there may not be any suitable spot for a tent. I've been in backcountry locations where I wanted to camp at an overlook but the ground was completely rocky and rough and no way to set up a tent. A companion with a RTT was quite comfortable, but I had to sleep in the passenger seat of my 4Runner (which works surprisingly well even for a 6'4" guy). If I did more camping, I'd get a RTT. I'll also second the person who mentioned being up higher -- I'd like being away from the scorpions and snakes looking for a warm spot on cold, desert night.
