6thGen1419
6thGen1419
Peter
New Mexico
  • Toyota does not publicly publish detailed micron efficiency ratings for most OEM filters, making direct comparison difficult.
  • “Higher filtration efficiency” can involve tradeoffs with oil flow restriction.
  • A filter that captures smaller particles is not automatically “better” for every engine design.
The_Dark_Knight_Forever
J.
Houston, TX
I've seen this information before. I'll pose these questions just out of curiosity & not out of criticism of others choices of how they care for their vehicles:
• Why wouldn't Toyota want to publicly publish the detailed micron efficiency ratings for their products when nearly all aftermarket manufacturers do so?
• It is possible that higher filtration efficiency can result in potential oil flow restriction...but aftermarket automotive oil filters are manufactured to meet or exceed the OE oil filters performance including oil flow & filtration efficiency. I'm pretty sure that respectable manufacturers are required to perform testing to ensure that their products aren't grenading vehicles as that would be determental to their customers & their company. There is also likely regulatory agencies involved in this as well. An owner can also compare the before & after oil pressure gauge readings on their instrument panel display to decide if they want to continue using oil filters other than OE Toyota.
• What is “better” for an engine design is usually open for debate in filtration matters...but how can having cleaner oil circulating through today's modern turbocharged engines be a bad thing as long as the oil pressure & resulting lubrication is within tolerance?
CO/ZA
Denver
25 4R ORP
Lol another oil filter thread!
Toyota engines run clean in general and don't necessarily need 99% @ 20 micron efficiency in their filters.
Because Toyota buys 999999999 filters from Denso each year, they do spec cheaper filter media that causes their filters to be known as rock catchers.
Denso filters are good, but built to a price point.
Nothing will happen if you use OE Denso vs aftermarket Wix / Mobil 1 / etc.
J.
Houston, TX
😂 Not my intention to derail or make the thread into “another oil filter thread”. It doesn't have to be. The OP started it about air filters but oil filters are a related topic. Nothing wrong with exchanging ideas, opinions & posing questions. No one knows everything...I certainly don't. Owners can do whatever they want to do with their own vehicles based on their own level of knowledge & risk acceptance. All said of course with open mindedness & respect. ✌🏻
6thGen1419
6thGen1419
Peter
New Mexico
I've not looked at mine yet but I'm all about being proactive rather than reactive with the maintenance & changing things. I need this 4Runner to last me for 15-20 years if I can help it.
I live in a large Texas city where there is always dust, dirt & construction going on. I also freeway drive 45 miles to work 3-4 days a week. So I imagine it wouldn't hurt to change my filters early & often.
Quality third party, after market filters vs. Toyota OEM filters aren't going to make any difference at all. My take is best to use Toyota parts because they are designed specifically for their vehicles.
6thGen1419
6thGen1419
Peter
New Mexico
Toyota oil filters are acceptable quality but still mediocre compared to some other aftermarket brands. They are on average only about $7 though so they are afforable mediocre quality if anything.
Can you point to evidence or data that supports your claims about Toyota oil filters?
CO/ZA
Denver
25 4R ORP
This video demonstrates his sentiments:
Toyota oil filters favor oil flow over oil filtration.
The folks on BITOG did observe a run of the OEM N1 filter suffering quality issues relating to pleats/glue some time ago.
Fact is, Toyota sells you filters at retail for $5 - meaning they must be paying Denso probably around $1-1.20 per can. They are built to a price, and the rather porous filter media reflects that.
To summarize, Toyota specs cheaper media that filters less because they believe the engines do not need ultimate filtering efficiency. This lowers their bill of goods. If you believe them, great, and if not - buy Purolator or Mobil 1 or something else.
bird
SF Bay Area
25 TRD ORP
Replaced my air filter and cabin with K&N’s. Been working great for me, it actually feels like the hvac blower is a little stronger than when I took delivery. Getting those extra pony’s where I can I guess lol 🤷‍♂️
K&N aftermarket filters let more airflow through at the expense of fine particulate filtering. Toyota doesn't make their filter restrictive for fun. I trust Toyota to know how to best balance air flux versus filtration quality and stick with OEM.
J.
Houston, TX
I can but I'd have to search for the YouTube videos I've seen & other sources I've seen. Anyone who has doubts or simply want to learn more about the filters, the different designs of them & the performance of them can also find the same videos & articles I did by searching for them & then decide for theirselves what they would like to do.
I said before, there's nothing wrong with sticking with OE Toyota/Denso filters. They meet Toyota's requirements & specifications, they're what Toyota prefers owners to use & they've been fine for alot of people for countless years. I'm currently using them myself but will eventually change my engine air filter & cabin filter to Wix & Premium Guard respectively. I've personally planned to change from the OE Toyota/Denso oil filters to CarQuest Premium oil filters at 15,000 miles but I might reconsider my plan & continue using the OE oil filters just because The Care Care Nut (aka AMD), who I believe & trust nearly 100%, has stated & urged his viewers multiple times in multiple videos to use OE oil filters in Toyota & Lexus vehicles. For those who aren't familiar with this Master Automotive Technician specializing in Toyota/Lexus/Scion vehicles you can view his generous content here. On the other hand though, he hasn't forbid using a reputable brand, high quality aftermarket filter if an owner has a track record of using it for many thousands of miles without any issues. Clearly choice & any potential risks are on the owner.
What I know to be fact is that my former 2003 Tundra had 363,509 miles on the original engine when I begrudgingly surrendered it to my insurance company as said earlier in this thread. It ran like a champ up until both OE cats were stolen off of it earlier this year. I owned & daily drove it from 17,000 miles until 363,509 miles. During it's life with me I used aftermarket filters for a vast majority of the miles I put on it & I never once had any problems directly related to the engine air filter or the oil filter (it didn't have a cabin air filter). That includes some shop provided brands of filters installed by Firestone Complete Auto Care (which I don't ever recommend) & some privately owned shops before I wised up after the first 7-8 years of ownership & started selecting my own oil & filters to use in it. With my modern 2025 4Runner & all it's complexities I'll definitely be very selective about what oil & parts are used in it as well as how things are done & who I choose for enevitable repairs.
6thGen1419
6thGen1419
Peter
New Mexico
Your video shows the Toyota filters to be less expensive than the other OEM brands the rated.
Also, the conclusion of the video is the Toyota filters had the least filtering and by far the most capacity (flow). Toyota intentionally builds their filters for high flow capacity and lower filtering.
I found this:
Not necessarily bad, and not necessarily nefarious. Oil filter design is a balancing act between:
  • Filtration efficiency (catching smaller particles)
  • Flow rate (ensuring enough oil volume reaches the engine quickly)
  • Pressure drop across the filter
  • Cold-start behavior
  • Filter lifespan
  • Engine design tolerances
Toyota has historically tended to prioritize consistent oil flow and low restriction, especially during:
  • cold starts,
  • high RPM operation,
  • long service intervals,
  • and engines with variable valve timing systems that are sensitive to oil pressure/flow.
A filter that captures extremely tiny particles very efficiently can also:
  • restrict flow more,
  • trigger bypass valves more often,
  • or reduce oil delivery under some conditions.
So Toyota’s philosophy is often:
“Adequate filtration with excellent flow and reliability.”
That’s a legitimate engineering choice.
A few important nuances:
“Less efficient” does not mean “poor”
Many OEM filters are designed around the reality that:
  • modern engines already have tight manufacturing tolerances,
  • modern oils contain strong detergent/dispersant packages,
  • and most harmful wear particles are in a size range the OEM filter does catch adequately.
Toyota’s engineers are optimizing for:
  • total engine durability,
  • not winning a laboratory micron-efficiency contest.
An ultra-high-efficiency aftermarket filter may look better on paper while not meaningfully improving engine life in real-world use.
Toyota engines are known for longevity
It would be hard to argue Toyota’s approach is catastrophically wrong given the reputation of vehicles like the Toyota Camry, Toyota Corolla, and Toyota Tacoma for routinely surviving hundreds of thousands of miles.
If Toyota filters were genuinely inadequate, you’d expect widespread premature engine failures across decades of engines. That evidence largely does not exist.
Why aftermarket reviewers criticize OEM filters
A lot of oil-filter reviews focus heavily on:
  • micron ratings,
  • beta ratios,
  • media density,
  • or “how much debris can this catch?”
Those metrics matter, but reviewers sometimes under-emphasize:
  • bypass valve calibration,
  • startup flow,
  • pressure stability,
  • and how the filter interacts with a specific engine design.
A filter optimized for a racing engine, diesel engine, or extended-drain interval may not be ideal for a Toyota commuter engine.
Could higher filtration be beneficial after break-in?
Possibly. There is a reasonable argument that:
  • during initial break-in, higher flow and capacity are desirable,
  • while later in engine life, finer filtration could marginally reduce long-term wear.
That said, the measurable real-world benefit for a normal passenger vehicle is debated and often small.
Where people get into trouble
Problems happen when people choose:
  • extremely restrictive filters,
  • cheap poorly-made filters,
  • or filters with incorrect bypass valve settings.
An “ultra efficient” filter that starves oil flow under cold conditions can potentially be worse than a moderate-efficiency OEM filter with excellent flow characteristics.
So the short answer is:
  • Toyota’s design choice is probably best understood as a conservative reliability-oriented engineering philosophy, not cost-cutting sabotage.
  • Whether it is optimaldepends on goals:
    • maximum lab filtration numbers,
    • maximum flow stability,
    • racing,
    • extended intervals,
    • cold climates,
    • or long-term daily-driver reliability.
6thGen1419
6thGen1419
Peter
New Mexico
Since when should YouTube videos be considered at accurate, fair, or unbiased?
I found this:
  • Filter lifespan
  • cold starts,
  • micron ratings,
  • beta ratios,
  • media density,
  • startup flow,
    • racing,
    • cold climates,
FrozenTater
Scott
Honda Crv
I get it, I trust Toyota for a lot of thing's as well and not in total disagreement,but it’s also like saying that no one should swap there air intake or put on a aftermarket lift ect because it goes against the engineering standards of the oem and they know better. To each their own. I’m not looking for fine particle filtration in my vehicle but appreciate the knowledge. Thanks!
CO/ZA
Denver
25 4R ORP
AI reply guy slop aside, this is my choice of oil filter:
https://www.rockauto.com/en/moreinfo.php?pk=478677&cc=3458784&pt=5340&jsn=627
https://bobistheoilguy.com/forums/t...110-c-p-toyota-90915-yzzn1-equivalent.390740/
"This is the filter Toyota should have adopted as the OE filter. Now that I’ve seen the thread of the missing glue end on numerous Denso N1 filters made in Thailand, this Beck/Arnley (made in Japan) filter is the best constructed alternative option filter if I’m looking for similar OE filtering performance ."
RockAuto is also a good source for the Wix charcoal filter and engine air filters.
I bought the Hengst one for the engine, as off roading dusty mountain trails tends to foul the engine air filter a little more.
mfoga
r4unner
Ok the air filter topic. If the KN are bad the Toyota TRD ones are bad too?
J.
Houston, TX
Those oiled types of air filters are meant more for high performance racing type vehicles. They are less air flow restrictive but not great at filtering out finer particles. The reduced Air Flow Restriction is what reportedly increases the horsepower by a marginal amount. They tend to be reusable whenever you clean them and re-oil them but the problem is that oil can cause problems with your mass airflow sensor in particular as I understand it. Aside from that the care of those filters is a real pain in the ass in my opinion.
In my opinion, those types of oiled air filters are not necessarily designed or meant for daily driver vehicles. When I bought my 2003 Tundra used the previous owner had installed a K&N air filter system in it. It kept tripping the check engine light because the mass air flow sensor didn't like the K&N setup so I had a mechanic remove the K&N filter system and went back to stock. I never had a problem afterwards.
