powder
seattle
2025 TuRDOR
There is definitely real power available from an intake alone — the testing showed that. And to be fair, increased sound and response can absolutely amplify the seat-of-the-pants feeling too.
I’ve shown how much tuning alone can unlock, even on the factory airbox. On a stock truck especially, the calibration side of things ends up being a bigger part of the equation than most people realize. And for anyone already running an intake, pairing it with a proper tune helps make sure you're actually getting the most out of the setup and the parts you already have.
In a bone stock vehicle with an intake only, the torque is a net zero if I’m reading correctly? And 10hp at peak? Theres no seat of the pants there, only placebo. but yes I’m sure combined with a tune you’d pick up something. Great data anyhow, it puts the speculation to rest
powder
seattle
2025 TuRDOR
Can you post just the banks and OEM to make it a little easier to read power under the curve. Also, did you do this test with the OEM vs aftermarket charge pipes?
ThatBronze4G
Kyle
Nebraska
2024 Tacoma/2025 4Runner
you will not see any gains from the charge pipes even with an intake. they're just additional parts needed for a tuned setup that would also most likely include a bigger intercooler.
CAMTuning
CAMTuning
Cam
NM
2025 Tacoma TRD OffRoad
10hp is not a placebo- non turbo Toyota guys would be thrilled to gain 10hp after an intake and a tune. With a tune on the turbo, 40-60hp is achievable.
Here you go:
2025 2026 4runner 6th gen Intake Power Gain Comparison (Factory, Banks, SXTH, K&N) — Same Truck, Day, Dyno, Surprising Results 1780527286304-il
I tend to agree here, but may test just to test my assumption. I have a set of brand new Banks charge pipes, and a brand new 4Runner I need to do some dyno testing on. I will likely repeat my SXTH vs Banks Intake testing, then add the charge pipes.
Vincenzo
Southeast
With the inlets and outlets using the same diameter as the stock charge pipes, I don’t see any significant gains.
powder
seattle
2025 TuRDOR
Here you go:
Thank you for taking the time. It doesn’t look like that’s the OEM and banks though?
CAMTuning
CAMTuning
Cam
NM
Sorry I misread the request and thought you wanted just sxth and banks. I’ll get the other graph when I get back to my laptop.
CAMTuning
CAMTuning
Cam
NM
Stock vs Banks. Peak numbers only tell a very small part of the story, so even though tq peak seems like only a very small gain, there is tq gained everywhere after peak.
2025 2026 4runner 6th gen Intake Power Gain Comparison (Factory, Banks, SXTH, K&N) — Same Truck, Day, Dyno, Surprising Results 1780566402393-lz
ThatBronze4G
Kyle
Nebraska
it's just wild to me how hard Banks gets pushed on the FB forums saying it's superior to the Sxth intake when dyno reports prove otherwise.
