- Joined
- Jul 23, 2025
- Threads
- 18
- Messages
- 359
- Reaction score
- 275
- Location
- Upper Left US
- Vehicle(s)
- 4Runner ORP & ā22 Tacoma OR
Same, two months in and not a peep since they did the TSB.
Pulled out of my garage and heard the cringey screechSame, two months in and not a peep since they did the TSB.
Most dealerships are going to want to hear it for themselves, and thatās all you need to do. Mentioning the TSB if they canāt verify the issue doesnāt mean anything Iām afraid, itās not like a safety recall.Pulled out of my garage and heard the cringey screech
Iām not far from my first oil change, do I just mention the tsb to my stealership and the will honor the fix ?
this is what Iām worried about bc it only seems to happen when the car is in the garage and I reverse out.Most dealerships are going to want to hear it for themselves, and thatās all you need to do. Mentioning the TSB if they canāt verify the issue doesnāt mean anything Iām afraid, itās not like a safety recall.
My dealership just told me the TSB is expired. This of course after they scheduled me for the work the day prior.I just happened to be at the dealership today and mentioned this TSB. Unfortunately the parts are on back order, but I have an appointment later this month to hopefully address the noise.
Did it work?Mine is being completed August 13 part already at dealership!
What's your source for the TSB's? I can see the current one (T-SB-0046-25) via the NHTSA site. Was just wondering what you were seeing?Thatās a lie unless theyāre looking at an older tsb. There are about 5 of them listed for brakes. Iād complain to Toyota brand tell them the dealer said it expired after they got you scheduled. Watch how fast they call you back to schedule it.
Toyota Technical Service Bulletin ā T-SB-0046-25
Date: July 24, 2025
Title: Front Brake Squeal Noise
Service Category: Brake
Section: Brake (Front)
Market: USA
Applicability
Year(s):
- 2025: 4Runner, 4Runner HV
- 2024ā2025: Land Cruiser
Introduction
Some 2024ā2025 model year Land Cruiser, and 2025 model year 4Runner and 4Runner Hybrid vehicles may exhibit a condition where the front brakes produce a squealing noise when driving in reverse. Follow the Repair Procedure in this bulletin to reduce the possibility of this condition.
Warranty Information
OP CODEDESCRIPTIONTIMEOFPT1T2BR2503R & R Front LH & RH Shim Kit, and Brake Pad Kit0.904945-601009199
Applicable Warranty Notes:
- This repair is covered under the Toyota Basic Warranty.
- This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicleās in-service date.
- Warranty application is limited to the occurrence of the specified condition described in this bulletin.
Parts Information
PREVIOUS PART NUMBERNEW PART NUMBERPART NAMEQTY04465-6038004465-34040Pad Kit Disc Brake, Front104945-6010004945-0C060Shim Kit, Anti Squeal, Front (Grease Included)104947-6015004947-0C030Fitting Kit, Disc Brake Front (Anti-rattle Spring)108887-80609Brake Caliper Grease1
Note:
Brake caliper grease is a common service consumable. Verify dealership stock before ordering. The amount of grease supplied in a single order is sufficient to repair 10 vehicles.
Required Tools & Equipment
SPECIAL SERVICE TOOLS (SST)PART NUMBERQTYDisc Brake Piston Spreader Wide09719-77020 / 09719-770501
Note:
Additional SSTs must be ordered by calling 1-800-933-8335 if unavailable.
Original Document:
Just got off the phone with Toyota's Brand Engagement Center and this has been superseeded by T-SB-0046-26. She was supposed to send me a copy and instead sent the T-SB-0046-25 version.Toyota Technical Service Bulletin ā T-SB-0046-25
Date: July 24, 2025
Market: USA
Applicability
Year(s):
Introduction
Parts Information
Note:
Note:
Original Document:
Sorry mentioned elsewhere it took shaving the pads like the old dirty trick on trucks back in the day ! So ya experienced mechanics know this !Did it work?
