All New Fox 2.5 Performance series Coilovers & Rear Shocks Installed on 6th Gen 4runner- Disappointing
AZGOLD
AH
Prescott
2025 ORP 4runner
Vehicle: 2025 ORP , 275 70 18`s GY Wrangler ultra terrains E load @ 34-35 PSI
Now, The ride is no better, if not, worse than the factory external reservior Bilstiens, Front & rear. So, just letting you know if you are thinking of going this route.
The front lifted nearly 2-3/4 inches which is great and I also installed toytec 2" lift springs in the rear. The rear springs are noisy and I think its because the coil isnt flat wound on the top like the factory springs.
Regarding the coilovers, I`m thinking the topout bushing Fox installed on the piston shaft is limiting the travel to like 4 inches
Anyway, be cautious if your thinking about the 2.5 Fox Performance series
2025 2026 4runner 6th gen All New Fox 2.5 Performance series Coilovers & Rear Shocks Installed on 6th Gen 4runner- Disappointing 2025 ORP Fox 2.5
Turbo8
Las Vegas
Did you make sure to torque all suspension bolts at ride height? If not, all of the suspension bushings are in a stressed state, which will impact the ride quality.
I'm talking about Lower control arm to frame and upper arm to frame bolts. Same with all the rear links.
xp0nex
2025 4Runner ORP
What is your use case for these shocks and why did you feel you needed to upgrade from the factory Bilsteins?
AZGOLD
AH
Prescott
2025 ORP 4runner
Because I wanted a suspension lift with no spacers, and Fox has always had a great reputation for a good ride. In hindsight , I should have stuck with the bilsteins, and waited until Toyota comes out with a kit. Another option would have been to get the OME kit which users seem to have good reports on.
Yes, Upper & lower control arms were tightened after settling the front suspension at ride height. The only one I settled in the rear was the anti-sway bar C clamps then retightened.
xp0nex
2025 4Runner ORP
Not all spacer lifts are bad. It really just depends on what you’re doing with the truck. If you just want some extra height, Peaks or Westcott is exactly what I would’ve gone with. No reason to drop a bunch of money on Fox unless you actually need what the Fox brings to the table.
From what I’ve felt, 2.5" shocks usually ride a bit stiffer than stock, kind of rough around town. But if you go ripping through washboards, the Fox will definitely outshine the factory Bilsteins. That’s where they really come alive.
spyder40
Indiana
2021 4Runner ORP
Where did you get your shocks? Accutune will set them up valving and springs dependent on what you want to do with the vehicle. Had 2.5 Fox with resevoirs/DSC's and Icon UCA's on my 2021. Rode like a dream and could make it soft or stiff depending on where I was driving. It was around 9" travel each corner. Gotta remember the shocks are inboard on the arms so the travel is more than the shaft shows
alldogsoffroad
Chad
Lincoln, NE
2025 Toyota 4Runner SR5
This sounds more like a tire issue than a suspension issue. E-rated tires significantly affect ride quality. I am running the Fox 2.0's and the ride is night and day better than the OEM suspension.
The foam bumpstop compresses, this does not affect uptravel.
One other note - Fox does a standard tune and an HD tune with their 2.5 performance series. What are the part numbers you have installed?
AZGOLD
AH
Prescott
2025 ORP 4runner
I did get the standard tune for both the front and the rear. I can’t remember the part numbers off the top of my head, but I did check them when delivered.
I’ll just suck it up for right now, and wait to see what Toyota comes up with.
Yes the E loads suck. I hate them but theres not to many options for C loads in a 275 70 18 .
PierceVonCloud
Tim
South Dakota
2025 Hybrid OR
... Accutune will set them up valving and springs dependent on what you want to do with the vehicle....
They don't have a tune yet for the Fox externally adjustable 2.5's on the 6G. I know because that's where I just got mine and they said they haven't had a 6th Gen in their shop yet. They just offer the Fox off-the-shelf tune and springs for now. I asked about softer springs and they made it sound like the 2.5 6th Gen "tune" would be the shim stack only - not springs. But when they DO get the tune developed, earlier buyers can send in theirs to get updated for free, i.e., the tune is included with the purchase like always. The fronts ship in one 76 pound box, so I hope I don't have to pay to/return shipping to California to get mine tuned eventually. Mine show up in a few days...
PierceVonCloud
Tim
South Dakota
2025 Hybrid OR
This may be a dumb question, but did you get it aligned afterwards? The toe would definitely change with that much lift and messed up toe can make bumps very harsh. Total toe should be zero, or very, very close to it.
AZGOLD
AH
Prescott
2025 ORP 4runner
Yes, Of Course I did.
As for the tires, they were on there with the factory Bilsteins so I would definitely notice if the ride was better.
This was Just a warning to others. They dont ride better than the stock on an ORP.
I`ll find something else after a while.
porkyfly
Mid atlantic
2025 4runner TRD Offroad
This is a strange observation. The factory red bilsteins had terrible ride quality so I swapped the rears for Fox 2.5. Ride quality is alot better now, but the front is still a bit harsh since it's on the factory bilsteins.
I guess Fox 2.0 is the safer choice? Seems counterintuitive that Fox 2.0 has better ride quality than Fox 2.5. Wonder why that is. Is there any way to quantify ride quality? Wonder if shock dynos are a thing
AZGOLD
AH
Prescott
2025 ORP 4runner
Yes , go with the 2.0 series.
I feel like the 2.5`s up front, are overkill on a light weight truck. Keep the 2.5`s in the back
porkyfly
Mid atlantic
could it be possible that the front springs have too much preload? The preload collar looks like its set pretty high up for the 2.75in of front lift. Could try moving it down a bit, i think a little bit of rake is good
AZGOLD
AH
Prescott
2025 ORP 4runner
yes it absolutely could and I do have a fox wrench to adjust the preload collar. Really didn’t want to lose the front height though.
I may try it however.
