jrdees916
jrdees916
Urbandale
4runner hybrid TRD Pro
I am sorry sent mine back to get heat shield installed. If I didn’t do it now I would regret it later. Count me out for about 1-2 weeks how ever long it takes for them to send it back.
Vincenzo
Southeast
This gives you ample time to get a dyno run, in, before installing
SC4Runner
Fred
South Carolina
I was just doing some additional research and will get mine ceramic coated before have it installed.
Key Benefits of Ceramic Coating a Downpipe
  • Drastic Heat Reduction: It acts as a thermal barrier, typically reducing under-hood temperatures by 30-40%.
  • Improved Performance: By keeping heat inside the pipe, it maintains higher exhaust gas velocity, which reduces backpressure and can improve horsepower.
  • Component Protection: Protects nearby wiring, plastic parts, and the turbocharger from extreme heat damage.
  • Increased Durability: Protects against rust, oxidation, and corrosion from road debris and salt.
JustDSM
Ogden, UT
2024 Tacoma TRD Offroad
We were able to get it knocked out quicker than expected. It's on it's way back to you as of this AM.
Enjoy!
2025 2026 4runner 6th gen OTT Downpipe for Hybrid 4Runner arrived 15005aec-42fe-49ac-89eb-df74daf578a1
2025 2026 4runner 6th gen OTT Downpipe for Hybrid 4Runner arrived b48c518d-94e2-4372-99f9-278c54d57695
2025 2026 4runner 6th gen OTT Downpipe for Hybrid 4Runner arrived dc644d14-caf7-46f3-9685-e7740ce859
jrdees916
jrdees916
Urbandale
Hell yea brother thank you for the quick turnaround
SC4Runner
Fred
South Carolina
I don’t have the exact dimensions, but I did place it on the floor by a yard stick, so you can get an idea about how big the Downpipe is. On another note, there’s a clip from CAMTuning with a cold start of a different brand of DP and a aftermarket exhaust. If this one is even remotely similar, it shouldn’t be too loud if you stick with the factory exhaust. BTW, the same thread goes into dyno analysis of aftermarket exhausts not producing much additional HP to warrant that replacement. So, I’m still going to have it installed, but I’ve decided to get the DP ceramic coated first.
@JustDSM, do you believe ceramic coating will be better than, not as good as or equal protection of the heat shield?
2025 2026 4runner 6th gen OTT Downpipe for Hybrid 4Runner arrived IMG_1926
2025 2026 4runner 6th gen OTT Downpipe for Hybrid 4Runner arrived IMG_1925
JustDSM
Ogden, UT
With the stock exhaust, the increase in volume is very minimal. There's a little extra volume at cold start when the wastegate is open (to heat the catalysts), but outside of that, it's all but imperceivable.
IMO, the insulated SS heat shielding will retain more thermal energy in the exhaust than a ceramic coating. The coating will better protect the 304SS downpipe from the elements, but the heat shielding we offer will do a better job of managing thermals.
That said, the reduced cell count and single catalyst in our downpipe will produce far less radiant heat in the engine bay than the stock downpipe. We found no heat issues with a raw downpipe during the 10K miles of street testing we put it through.
Best,
HVLA
Lexus
Are there dyno numbers for this pipe? $750 is a lot of coin for sound.
I am assuming there are benefits?
SC4Runner
Fred
South Carolina
The DP is $1,500. The performance gain, paired with other mods and compensating tune should be significant. Estimates I’ve found in my research and limited knowledge indicate 340-370 HP for non-hybrid, but @JustDSM will have a much better idea than me.
HVLA
Lexus
$1,500??? Holy crap LOL
Scrappopatamus
Barry
Midway KY
Did anyone ever get one of these installed and if so, what's the score?
jrdees916
jrdees916
Urbandale
Mine is going in this weekend. Been delayed due to weather here in Iowa. I will give it my review after install
