Ahmad310
Ahmad
Cincinnati, OH
2025 4Runner Platinum
Better. Now under $140. Tempted. Still a few hours left before the sale ends.
Find some other products and get them while on sale. Hard to beat! I picked up the emblem, the gloss black rear overlay, the side compartment multi tool and the OEM TRD Pro Mudflaps (for when i put bigger tires)
beaninno
Tim
Mandeville
I watched the video on youtube from Yoti Expedition to install and was taking off panels above the radiator then feeding thru the grill. It looks like I can’t do that bc there is a louver system there and feeding wire thru would block it from closing. How did you do it ?
Ahmad310
Ahmad
Cincinnati, OH
TMLifer
Thanks for installation instructions. There were none in the box. Still not seeing where to feed the wire thru to the front grill. I’d don’t see any openings above the louvers.
Hopefully you have since found the small gap where to feed the harness through. But, if you haven't, I'll try to describe the location. It's definitely a tight (small) gap that I had to finesse the harness and connector through. If you reference Toyota's instructions from the link that @Ahmad310 provided, it is Step 17 on page 6. The gap is located underneath the black tab (left of the hood latch if you're facing the front of the car) at the top of louver system.
beaninno
Tim
Mandeville
Thanks ! Going to work on it this weekend! That info will help alot.
Vincenzo
Southeast
Why Toyota chose to put a Prius emblem on the 4 Runner. I chose to go this route
2025 2026 4runner 6th gen OEM Illuminated Front Emblem: Dark Chrome w/ Light Up LED installed [+ part number / price] IMG_8647
bigbruse
robbie
va
2025 4runner
First mod, replacing the front chrome Toyota emblem with a smoked out dark chrome light up one.
Toyota OEM part name and part number:
Part number
PT413-89250
$185 MSRP
Part number
PT413-89250
$185 MSRP
How hard was it ? Do you have to take off the grill? I already have the illumination. Mine is the chrome. I just want to switch out to the black one.
TMLifer
Installation wasn't difficult. But your case will be a little different. Your wiring for the illuminated emblem is already in-place. All you have to do is remove your existing illuminated chrome emblem. I had originally had a regular emblem installed when I purchased my vehicle, so it was easy to remove because the original, non-illuminated emblem had voids which allowed me to stick my finger through and behind the emblem to unclip the tabs holding it in-place. In your case, your existing emblem is an illuminated emblem which is a solid emblem without any voids. There's not much online information or videos about how to remove the illuminated emblem because I think it's so new. I haven't tried looking yet, but you might be able to unclip the tabs on the illuminated emblem from the back side of the emblem without removing the grille.
beaninno
Tim
Mandeville
How did your installation go?
Thanks for checking back. After got the paper print out and ya'll input, it was easy.
I pull up on that grill tab on top alittle and fit plug through it.
I appreciate all ya'll help. Thank You!!
Happy Mardi Gras!
ctreble
irvine
Website
leapchiropractic.com
2025 4Runner Heritage Blue
For your raptor lights do you think you can tap into the illuminated emblem for power instead of fuse box? Or maybe just get another harness PT413-89250-AC from dealer and plug in play the other light for raptor light power?
TMLifer
Hi @ctreble, I know that my avatar has a 6Gen 4Runner with raptor lights or additional fog lights on it. But, the avatar is not a photo of my 4Runner. It's a generic photo that I found. I haven't installed raptor lights and not familiar enough with the requirements and specs of raptor lights to provide an answer. There may be fuse size and also connector compatibility between the harness and the raptor lights to consider if you plan to do that.
horbit
DFW
I have the same exact idea, will probably try it when I decide on a raptor light.
