RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
I have the same Toyo 275 E-load tires in 17in and really like them, but I didn’t get a 5th spare. How manageable is it to replace the spare and does it look weird at all when mounted? Just curious.
As a sidenote (from both experience and speaking with Toyota tech) these E loads need balancing more often. I’ve already put over 5k miles on them but needed a balance at 4k miles.
Thanks for the tip on rebalancing.
What PSI are you using ?
We had these same Toyo's for 5+ years on our 2020 Ranger in E-load LT265/70 R17. Traded our Ranger in for our 2026 ORP. Win! πŸ†
Our ORP came with four optional black 18" wheels (PIO) and a full-sized spare that had the original 18" silver ring wheel. I won't do 5-tire rotations and left the mismatched spare wheel, but the tires all match.
Replacing the spare tire is easy... for Discount Tire! I lowered the spare onto my creeper dolly, rolled it out, then put it inside the cargo area so DT didn't have to lower & raise it. I rechecked the pressure, then reinstalled the spare myself. The chain hoist is smooth and easy to use. I found that while nearing the top, need to rock & wiggle the spare around to make sure it's fully seated in the forward brackets.
Several here have 285 spares. Our LT275/70 R18 spare looks to be the max size to fit up in there.
View from the back...
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  Spare 2
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  Spare 1
croome21
Cal
2025 Toyota 4runner SR5
Thanks for this! I’m running around 32 PSI
BonRunner
2026 TRD Sport Premium / WCP
Cali Raised Ditch Lights installed. 27W with side-projecting LEDs. Love it so far! Very bright at night and helped with peripheral views to watch out for wildlife! I have adjusted them to be at 10 & 2 o'clock position with slight tilted down.
The pods have slots for amber lens attachment that I may get in the future.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  image-1768186884027
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  20260112_003657
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  20260112_003638
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  20260112_003706
RIGID makes amber and solid black covers that snap onto the caliraised ditch lights.
ItsmeAlex
Alex
Plano Texas
Ice Cap 2025 TRD ORP
