- First Name
- Justin
- Joined
- Jan 31, 2025
- Threads
- 32
- Messages
- 466
- Reaction score
- 471
- Location
- Wylie Texas
- Vehicle(s)
- 4Runner ORP and Avalon
I've got a TRD ORP with the standard black recovery points (2 front, 1 back). Photos below. My question: is there a functional improvement going with the red Toyota recovery points (or something like this sxth-element prototype)? Or is it mostly about looks? The alternate recovery points all seem to provide maybe a bit more access but its not clear to me that there is a real functional benefit. But I don't know which is why I'm asking. (And to other question above, I am not recommending this but was gifted it for xmas and look forward to using it to help someone ELSE out of being stuck: Hokinety Recovery rope)
TRD OR recovery point rear:
TRD OR recovery points front (black in front of shock to either side of skid pad):
I am far from an expert so I asked a computer if it was just for looks or not and I thought it was a good answer
Here’s a clear breakdown of what’s going on with Toyota’s standard black recovery/tow points on your 2025 4Runner TRD Off-Road and the Toyota upgrade (Part No. PT974-89251-03) — and whether the upgrade is just looks or if there’s functional value to it:
- The black loops/hooks on your 4Runner from the factory are typically tow/tie-down points and not marketed with a specific heavy off-road recovery rating like you’d see on dedicated, rated recovery hooks. (IH8MUD Forum)
- Many Toyota tie-down/tow “loops” have historically been designed to meet shipping, transport, and light towingspecs, not the dynamic and multi-directional loads you see in a full off-road recovery. (IH8MUD Forum)
- Some owners and forums point out ambiguity in Toyota’s documentation about whether factory hooks are “recovery rated.” (IH8MUD Forum)
- Toyota’s parts listing describes PT974-89251-03 as a genuine rear recovery/tow hook engineered to support off-road recovery tasks — stronger and more robust than generic tie-downs. (Toyota Direct Auto Parts)
- Community reports also mention that this OEM part feels heavier and more substantial than the black factory piece, hinting at a more solid build — not just cosmetic. (4Runner6G)
- There are hints that the upgraded part may come in a TRD Red version (e.g., PT974-89251-AA for the right side), which more clearly identifies it as a recovery hook and looks more purposeful than plain black. (Toyota of Hackensack Auto Parts)
Not purely. While looks are part of it (e.g., red finish on the upgraded hook), there is likely some difference in functional intent:
So while the OEM upgrade is designed for better recovery use and is better quality than simple tie-down loops, it may not transform your stock loop into a high-strength, off-road recovery anchor in the same way a dedicated, rated aftermarket pair would.
If your priority is functional, off-road recovery strength — especially for serious situations (winching, angled pulls, kinetic rope, etc.) — you might consider proper, rated recovery points that bolt directly to the frame. Examples include:
- 25+ 4Runner SXTH Element Recovery Points (Black) – CNC-machined hooks with higher load capacity than stock.
- 2025‑Current Toyota 4Runner Lower Front Recovery Points Blac – steel frame-mounted points designed for robust recovery use.
- Nytop Rear Recovery Points For 4Runner (2025‑Current) – aftermarket rear points with solid capacity and frame mounting.
- Standard black hooks: Good for light towing and tie-down duties, not purpose-built for heavy off-road recovery.
- Toyota upgrade (PT974-89251-03): More robust OEM recovery hook — better than stock and tangible improvement beyond aesthetics, but still might lack formal recovery load ratings.
- Best for heavy use: Dedicated aftermarket recovery points designed and rated for off-road pull/kinetic rope use.
