Remove spare when going bigger than 33's?
Bigger than 33 will fit with a slight mod. I fit a 285/70/18 as a spare. With a K03 that’s just under 34”. Thread for pics and comments if you’re interested is
Largest size spare tire fit in undermount carrier?
I personally wouldn’t be out in a remote spot without a spare.
Ive gotten the same tire size except my rim is a +18. How are you fitting it? Everyone’s been saying ya can’t fit more than a 275 under.
Cranberry
Manitoba Canada
Not running a spare if your going off road is a concern to me.
from my research and confirmed with measurements at the dealer a month back, The gen 6 Will handle up to a 275 tire at 35 psi in the spare tire area. A 285 will fit if you deflate the tire down to 10 psi.
Its the identical size as the 5th gen spare tire compartment.
i run an air compressor, so keeping a 285 to match my full current load makes sense to me.
rutsnext
British Columbia
2025 4Runner ORP
Pic of the bracket you have to deal with. The thread I highlighted shows more pics of the tire in the carrier including how it’s right up against the hitch receiver. But if you deal with the bracket it fits fully inflated. 285/70/R18.
If you want any other pics or info lmk and I’ll DM you.
2025 2026 4runner 6th gen Remove spare when going bigger than 33's? IMG_8334
Cranberry
Manitoba Canada
you may want to also reference the exact tire your using.
i run a Falcon Wildpeak AT4W 285 currently and can confirm these will not fit in the spare tire area unless i deflate the spare tire, however if i run 285 non AT tires i can fit them in the spare tire bay.
rutsnext
British Columbia
2025 4Runner ORP
I run a BFG K03. All the detail is in the thread I referenced in my earlier response. KO3 is 33.7. AT4W is 34. And I agree, and referenced in my post, that the 1/4” would make a difference.
So, yes, your comment is fair. Would be great if threads discussing the same topic were linked.
rutsnext
British Columbia
2025 4Runner ORP
And to not risk any misunderstanding, you have to modify the bracket to make it work.
jayT
Banned
Banned
Banned
john
Louisiana
I put 285 70 R17s on my rig and replaced the donut with full SPARE of the same size..seeing that tire from behind, underneath my 2025 SR5 PT4WD looks badass..lol
4NAUSET
NYC
2025 4Runner TRD PRO
Currently have 285/70/18 Falkan Wildpeak AT4W on stock rim mounted underneath with no modification - Toyo AT3 285/70/18 also fit but the E rated as advertised was a rough ride
xp0nex
2025 4Runner ORP
Fits without any mods?
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
I guess that's based on what you have driven in the past. My 4runner with E rated tires, Westcott spacer lift and Dobinson coils is smoother than factory.
Not true! If you’re running E Rated tires you need to have them aired at the appropriate amount that won’t feel that way to some.
I keep mine on 33-35psi! Smooth for me.
jayT
Banned
Banned
Banned
john
Louisiana
no mods needed..they did not rub at all when first installed. a day later, i installed a Rough Country 1.5"-2" leveling kit..so, i really like the STANCE now...
